What's a new early type 3 exhaust worth - now with photos
Never fitted, please can you tell me what's it worth
Now: 72 fastback, B5 RS4
Gone: fastback 72 73 68 and another 72
Re: What's a new early type 3 exhaust worth
Silencer on its own-around £120ish
Two part tailpipe-Damper pipe around £15 Tail pipe tip-£25+
How early is it??
Has it got the heat exchangers built in?
The other major factor is the quality. I've taken budget ones to shows priced at £80 and brought them home again. The genuine VW marked exhausts are likely to be £150 or more, and are worth all of that, in longevity. Effectively they are tuned, with equal length 4 into 1.
The attached heat exchangers went to '64, but they are very rarely found now. Later had the separate heat exchangers, with small bore damper/tailpipes to '71, and then they had a bigger outlet and used the big bore one-piece damper/taipipe. Quite a lot now have the bigger bore anyway.
Re: What's a new early type 3 exhaust worth - now with photo
Thank you for all the info, I have now put photos up for a more accurate estimate
The one-piece tailpipe is for a big-bore (8/71 on), and worth around £35, which goes with the Leistritz big-bore silencer. I agree with Peter's valuations on that and the small bore tailpipe and damper pipe.
