Fuel shut off valves for 32 PDSIT?
Hi All,
Mine are getting on a bit, with the LHD side sometimes being faulty, anyone know of a source of these, I'm after a pair for my Square.
73 de Wayne M5WJF
Re: Fuel shut off valves for 32 PDSIT?
I think they are the perhaps the same as for a 2 litre T25 - worth a look ??
They also act as the idle jet - I would be surprised if it's the same as 2litre Type 25, but I've no certain knowledge. Some can be at least partly dismantled - there's a screw in the end that disables the cut off mechanism in case the solenoid goes open circuit. Check the connector and wring is good - the wiring on mine had got down to a strand or two. Maybe try some carb cleaner in case it's got gummed up.
The CU engined T25 runs 32-34 PDSIT carbs as standard (after all it's just a big bore detuned type 4 engine)
I was looking around for bits for mine a few months ago and saw some on VW Heritage, which is what brought my initial reply.
Here's a link, take a look, I haven't got a type 3 so I just don't know https://www.vwheritage.com/shop/type25- ... StartRow=1
I fired up the parts catalogue and assume its part number 311 129 413 J you are looking for
If so, here's another source https://www.mecatechnic.com/en-GB/_C071563.htm
Looks similar to the T25 one, but obviously not exactly the same
The ones in the Type 3 parts book are quoted as g50; Type 4 are g55 (and are actually Beetle parts 111 129 413G).
The ones in the URL are g45 for engines up to '66, though 12V (maybe for conversions?). I don't see why it shouldn't be possible to enlarge those jets a little with care if the idle was too lean. They're not cheap though, at 60 Euros each.
Dave, you certainly know your stuff, you are of course absolutely right.
Looking at the information you have provided I can now see how the information was is the electronic parts catalogue all along which lists parts from earlier models as well as the actual model year selected, I just wasn't reading it all correctly. On the other hand at least I have learnt something today.
After a bit more internet searching I have found a guy in Australia who has them listed, but quotes part numbers 058 129 413B for the type 3 and 058 129 413D for the type 4 which seems to be widely available ?? http://www.mickmotors.com.au/group_1_catalogue.html
Still, I suppose that at least there is a source for the early type 3's, (6V as well) at a price
ps, just did a look up on the 058 part number without a suffix and the E version for the T2/T25 I mentioned in the first reply seems to be a G52.5 (which I assume is the jet size)
I hope this is helpful, rather than just confusing Wayne
Yes it's the jet size, so would make a bit of a difference, and as you adjust the carb mixture at idle, I suppose any difference from spec would show in running a bit leaner or richer depending on the jet size.
I don't 'know' these figures, I look them up! I guess in driving Type 3s for 50 yrs, I've 'been there, read up on that' a few times. As I get older ('matured' according to my son's recent birthday card to me!) I forget more, and the parts book and references are a great help. I've probably looked much of it up before - I like technical books, though definitely read for info rather than relaxation!
I found that Carburettor Hospital stocked the G50 12v as NOS, so bought a pair for £40 each, plus delivery.
Their email is chipmork@btconnect.com, to determine whether they have the part (picture exchange, etc), payment is over the phone by card on 01702 203286
73 de Wayne M5WJF
