A quick parts ident?
Post by purplepeter » 8th February 2017 - 10:51pm
Please can anyone put a name to these?- Don't need part numbers, just an id !
Firstly, pipe at bottom of pic: 34cm long, 20mm internal narrowing down to 15mm internal
Next up Rubber clamp type thingy
Bag of ? oil/brake fittings?
2 X metal cased seals.1 is 62X10 ext & 45 int, 2nd is 90X13 ext & 70 int (mm)
Any helpful suggestions would be appreciated!
miketyp3
Re: A quick parts ident?
Post by miketyp3 » 9th February 2017 - 8:16am
First up could be the early fuel tank vent hose if the narrowing is just about 20mm at one end.
Second is definitely the steering column mounting to the dash panel.
I don't recognise the parts in the other two pics.
Post by purplepeter » 9th February 2017 - 4:57pm
Thanks Mike
More info on the bag of bits; it contains 1 Nylon washer, 2X steel washers,1X circlip,2 copper washers & the 2 slotted/pronged washers seen in the pic. The big fitting appears to have a 1 way valve inside it & has male & female threads that look like brake/oil pressure switch
