Bentley manual does not cover carbs?
sima112
Post by sima112 » 15th August 2017 - 8:41pm
Hi guys,
I've just bought Bentley manual and with disappointment found out that it does include fuel section for carbs and manual fuel pump.
Does anyone owns a different edition of the manual or some which cover fuel section for double carb (mine is squareback 1971),
and be so kind to copy this chapter for me?
I'm not keen enough to order another manual, because Im located in Colombia and the postage is same as the value of the book.
Many Thanks Sima
Re: Bentley manual does not cover carbs?
Post by purplepeter » 15th August 2017 - 10:16pm
If it's any consolation, We're all jealous of Your proximity to Klassic Fab !
This may help https://www.thesamba.com/vw/archives/ma ... /index.php
and this viewtopic.php?f=14&t=3105
The Bentley Manual was for the US Market, Hence no coverage of Carbs
Haynes covers them quite well- I'll see what I can do re scanning it for You
sima112
Post by sima112 » 16th August 2017 - 4:14am
Thank you very much purplepeter,
This will be definitely helpful. I'd also kindly ask for the fuel pump section as Bentley again has only electric pump covered, not mechanical.
If possible.
Thank you Sima
Post by purplepeter » 24th August 2017 - 9:54pm
Check Your email, Sima112- 16 pages of Haynes emailed to You this morning!
Do yell if You need more!
sima112
Post by sima112 » 27th August 2017 - 5:48am
Great stuff,
you are a legend! Thank you so much for your time and help
Sima
