Rear Subframe Diff
Maccattack
Rear Subframe Diff
Post by Maccattack » 18th February 2018 - 10:01pm
Hi All,
Does anybody know any diff between rear subframes. I was told the distance between center of each shock to body bolt should be 910mm.
I have an auto irs subframe at 910mm that came off the car, a manual irs at 900mm and a swing axle at 895mm....
All frames measure up as square and true....
My swing axle frame has been converted with irs inner mounts but is narrower than the original irs auto frame between the shock towers. Frame to floorpan bolts line up perfect and frame measures square.
Does anybody know of differences in frames?
AK
miketyp3
Re: Rear Subframe Diff
Post by miketyp3 » 19th February 2018 - 1:31pm
There shouldn't be any difference.
It seems a lot by todays standards, but I imagine 5 - 10mm could be build tolerance.
I have used the same IRS subframe from a late Auto Squareback on 2x 64 Swing Axle Notchbacks while they've been restored.
As far as I remember its fitted straight on both - its a fairly big hole / washer arrangement...
Maccattack
Post by Maccattack » 19th February 2018 - 5:36pm
Thanks Mike, best thing then to see of will fit the body Ok when I have the access.
