Was someone looking for a dynamo?
Questions and general discussion on all things Type 3 & 4
Post by broady_6 » 31st May 2013 - 10:28pm
Im sure someone on here recently asked for a dynamo.
I found this on ebay, http://www.ebay.co.uk/itm/VW-Type-3-Fas ... SS:GB:1123
And its 12V a bargain for someone
Re: Was someone looking for a dynamo?
Post by Editor » 1st June 2013 - 12:12am
I can't see a brush in the holder that's visible - I've asked him if there are any.
The connector is a later style too - not the usual separate D+, DF and earth connections.
Marko
Post by Marko » 1st June 2013 - 8:47am
what's the difference between a Type 1 and Type 3 dynamo? just curious..
viewtopic.php?f=4&t=6896
Post by purplepeter » 1st June 2013 - 9:18am
Type 1 has a shaft sticking out of the end to attach the fan to
Marko
Post by Marko » 1st June 2013 - 9:21am
purplepeter wrote:Type 1 has a shaft sticking out of the end to attach the fan to
of course, silly me!
cheers, Mark.
Post by broady_6 » 1st June 2013 - 3:36pm
i believe the diameter is also different an they use different pulleys
Marko
Post by Marko » 1st June 2013 - 5:23pm
I have one sat in my garage collecting dust but I'm a bit reluctant to sell it in case I ever need to put it back to stock.. same with the regulator I have knocking around, you could of had that for peanuts if I knew I would never need it! my alternator set up seems to be working out OK by the way :)
Mark.
Post by broady_6 » 1st June 2013 - 8:15pm
I'm not sure who it was that had been looking. I'm staying stock as its not caused me any issues on any of my current or previous cars. Got myself a couple of spares too!
markthehat
Post by markthehat » 4th June 2013 - 8:45pm
Was my son looking for one. Have used a type 1 we had knocking about in the end. just swapped pulleys over. :D
Post by Editor » 6th June 2013 - 1:07am
I don't think that's a good thing to do. The cooling air can't get in if you use a Type1 on a Type 3. The end of a Type 3 is solid, and there's a hole in the underside that matches one in the fan-housing, so the fan drives cooling air through the dynamo. On a Type 1, the fan forces air axially through the dynamo (or alternator) end-plates.
I've also read something on the USA forum about the brush springs not being set up the same on Type 1 as Type 3, leading to rapid brush wear, due to the unit rotating the opposite way. I had to think hard about that, but the brushes are at opposite ends on the Type 1 and Type 3, so effectively the unit is backwards on one compared with the other.
I presume if you are getting charging current, the generator has re-polarised itself. I recall someone connected up a battery the wrong way in my father's 6V Beetle many decades ago. It worked OK, and continued to work OK after the battery was reconnected correctly. I guess the only thing affected was the side of the points that usually got the hollow, got the pip instead. No electronic flasher unit or whatever to be affected on that 50's car.
markthehat
Post by markthehat » 6th June 2013 - 9:06pm
Hadn't even thought about the cooling ! Haven't stripped the type 3 one yet, hoping its just a broken wire otherwise it's get it rewound or buy a new one. I will want it back for the trekker at some point !! when i've finished restoring it :-)
Post by Editor » 9th June 2013 - 12:06am
Sometimes it is as simple as the fact that the pole that the DF wire connects to has been rotated and broken the field coil winding (hence no circuit to provide the magnetic field.
That's assuming the armature isn't burnt out (rewind essential) or the brushes worn down (easy repair).
markthehat
Post by markthehat » 9th June 2013 - 8:37pm
We changed brushes but havent checked anything else yet too busy separating trekker body and floorpan !!
