It Looks like I'm going to be cutting up a floorpan this weekend!
I'm keeping Framehead & Floorpans, so please don't ask!
Does anyone want/need any of the remaining sections? ie Tunnel & spine?? God knows Why You'd want these bits, But thought I'd ask, Just in case!
Let Me know ASAP.. I'm Planning to start cutting on Saturday!
Chassis cuts
Re: Chassis cuts
Peter,
Amazing! Could I have the centre tunnel (top and bottom) from behind the frame head up to the gearshift?
Reason - someone has hacked into the tunnel on my T34 to change the clutch cable (really!) and underneath its got a massive dint in it - not sure what that is all about...
I can pick it up on 22nd if we're still on for then.
Cheers,
Cheers,
Re: Chassis cuts
Yes, Mike.. I'll cut the pans in such a way as to preserve those sections. How far ahead of the front bulkhead do You want?(I'm referring to what would be the Napoleons Hat on a Bug)
22nd is Good
22nd is Good
Re: Chassis cuts
Thanks Peter,
Behind the bulkhead is fine, in fact the damage inside the car is behind the holes the pedals go into.
I don't actually need them to be together and I don't need right down to the floor on the upper bit either if that helps.
I'm gratefull for whatever you can spare, so cut the pans out which ever way works best for you.
Why is it scrap? It sounds like its a good pan.
