Ignition timing
mawsy
Ignition timing
Post by mawsy » 5th February 2018 - 12:09pm
Hi all having a nightmare setting up timing on my 72 square, was running then started missing and popping changed dizzy to electronic acuspark , with new coil, no better , process of elimination found starter bush had failed, replaced and had starter reconditioned, at last problem sorted. Set up timing light started on button timing spot on , had cup of tea returned and started again , spot on with timing light. Tightened dizzy holding clamp tried to start no joy , will pop and fart but not run. Help please cheers Mawsy :
Re: Ignition timing
Post by purplepeter » 5th February 2018 - 1:03pm
Depending on how much You've loosened the clamp, its perfectly possible for the dissy to move whilst running/cranking- Start again & tighten the clamp as soon as You're happy with it, or loosen it so you can only just move the body
mawsy
Re: Ignition timing
Post by mawsy » 5th February 2018 - 1:13pm
Have tried turning dizzy to no effect, just hoping electronics not kaput
Re: Ignition timing
Post by 937carrera » 5th February 2018 - 4:01pm
Looks like you disturbed something when tightening. Have a look round if you could have disturbed a connection, otherwise, back to basics, use a spare plug and see if you still have a spark.
It is unlikely that something else has failed......but that means it is still possible, check daft stuff as well, you still have fuel ?
Re: Ignition timing
Post by broady_6 » 5th February 2018 - 8:13pm
Could be more simple than that, the dissy can ride up while its loose. If its too loose you may find its come up enough for the drive dogs to disengage. Take the dissy cap off and get someone to crank it and see if the arm is going roundy round.
mawsy
Re: Ignition timing
Post by mawsy » 7th February 2018 - 4:05pm
Hi again noticed dizzy rotor turning intermittently, removed dizzy machined 2 mm to allow deeper drop, running a bit ough will fit strobe and sort it hopefully cheers all Mawsy
mawsy
Re: Ignition timing
Post by mawsy » 8th February 2018 - 11:22pm
Sorted now cheers all Mawsy
Re: Ignition timing
Post by 937carrera » 9th February 2018 - 2:03am
What was the final solution then - so we all learn ? :)
mawsy
Re: Ignition timing
Post by mawsy » 23rd May 2018 - 10:53am
Final solution to dizzy problem was to go back to vaccum advance dizzy as the electronic in my experience was pants, running better now but left hand carb not accellerating, will take off and investigate cheers Mawsy
