help choosing a floorpan gasket
- Tight yorkie mick
Hi folks as the title, I'm now at the point of needing a pan gasket ordering . but I'm not sure what to buy and were from? Are they same as bug? Is cheaper less cheerful ?
Any help much appreciated thanks
Ps please remember my forum name and break any bad news gently
Re: help choosing a floorpan gasket
They're not the same as a beetle, but as that's all that's available its what you have to use.
From memory you need two as they aren't quite long enough.
The rear corners are a lot tighter on a type 3 and its a struggle to get it to go round in one piece - the original seal had moulded corners and was nailed in place.
- mjrpoulton
Try and find one suitable for a type 1 KG, which is longer due to wider pans. On the rear corner on the KG the join is mitred or overlapped since it's almost a right angle.
Mark
Mark
Mark
1972 411LE 2 door
1968 type 345 auto
1967 type 344
1972 411LE 2 door
1968 type 345 auto
1967 type 344
- Tight yorkie mick
Thanks for your advice folks , I've found a few places that advertise extra long rolls for type 3 and Ghia, so I'll let you know how it goes.
Can you let me know where you found extra long ones as I'm at the same point on my fasty
- Tight yorkie mick
Hi David I've ordered one from heritage advertised as type 3 wtra long, as Deimos are sold out, I'll post back when it arrivessplitybus wrote:Can you let me know where you found extra long ones as I'm at the same point on my fasty
- Tight yorkie mick
Just a quick update on this,
The heritage one was plenty long enough. But I did end up pie cutting it for the tightest corners and using sikaflex type sealer to stick it down held in place by masking tape and left overnight to set.
This guy explains better https://youtu.be/M9NSya2TN9M
