Type 4 1700 Find vacuum can
The vacuum can on my dizzy doesn't appear to be working anymore. Any idea what can will fit and work on a type 4 dizzy?
Re: Type 4 1700 Find vacuum can
On the actuating arm/lever inside the Dissy, You'll find a number stamped Shawn- that's the important thing
As before, check with Jim Bourne to see if he has a spare. He's collected so many Type 4 bits over the 30 years he's been in the Club. If not, check with Jane and Bryan. pm for phone nos if you've lost them.
Should be dry tomorrow so I'll have a look see
The number on the lever is 461...
Check with Jim/ Jane & Bryan
I'm up at Derek's on the 9th April, So will check there then if You're not already sorted by then
Spoken to Jane earlier and arranged to go up the Farm on Thursday, should be sorted then
After visiting the farm for a tune up the 411 is running far better.
Replacement vacuum can fitted, injector points regapped and valve clearances adjusted
