Heater Controls
Heater Controls
I am missing the slider control knobs from the drivers and passenger side panels. The wires are there and can be pulled, moving the flaps. Any availability on the control knobs, or alternatives?
Tony
VW 1970 Square
VW 1970 T2 Campervan
1980 (ish) Eriba Puck
(Yucky renault for normal day driving.)
VW 1970 Square
Re: Heater Controls
No promises Tony, but I might have some.
Do you also need the trim plates they run in and the clamps for the wire?
Re: Heater Controls
Mike, that would be great if you do. Will take a photo of how they are and send it over to you,
Tony
VW 1970 Square
VW 1970 Square
Re: Heater Controls
I remember having the complete set up and all I needed were the flaps & wires. I'm hoping I still have what's left, as I vaguely remember photoing them for someone - I will start looking tonight...
Re: Heater Controls
I'm sorry to say Tony I don't think I have them any more.
I had a good look over the weekend and yesterday found the flaps and wires, but the bits you need are not with them.
As I said, I remember taking a picture of them for someone, so it looks like I let them go.
Unfortunately they are the sort of thing that often gets taken off and lost, but hopefully someone has some for you.
Apologies for keeping you waiting.
Re: Heater Controls
Thats fine Mike, thanks for looking.
i will ask around.
Tony
i will ask around.
Tony
Tony
VW 1970 Square
VW 1970 Square
Re: Heater Controls
I must have some somewhere - I'll see. Is it just the knobs you're missing, or do you need the threaded rod and plate that slides in the channel behind that the knob screws onto to clamp the cable? http://home.clara.net/hallvw/type3/T3pbo/T3pb2-18.htm items 38 shows the flap and clip and wire as well, but how much of the rest are you missing?
Re: Heater Controls
Hi Dave, I will take a photo a post it over. I've also asked back at Paul Medhurst at T2D.
Many thanks,
TH
Many thanks,
TH
Tony
VW 1970 Square
VW 1970 Square
Re: Heater Controls
The knobs have a plastic disc which should be carefully removed to get to the screw that holds them on the spindle. You need a thin screwdriver blade (electrical type?), but the knob part is fairly flexible plastic It is possible to lever the knob off, but it tends to damage the knob.
