Hi,
I'm on the hunt for some new rear axle bump stops, but I'm not sure the 1.... Yes 1 I've removed is actually correct??
My car is pretty lowered so I don't know if I'd want the standard ones anyway? How do the standard ones mount? Can you cut them down?
Cheers!
Rear axle bump stops?
Re: Rear axle bump stops?
No, that's not an original.
They are normally a bit taller than that. They push on to a "mushroom" feature formed on the bracket.
Ah, cheers for that.
I have no mushroom, I have a hole instead.
I'll look for a universal pair to screw in, better than nowt I guess.
