Hi
firstly, sorry for the noob question. Ive searched but couldn't find the answer.
I would like to run 5x112 wheels on my 73 square which is 4x130.
I've seen the blank discs/drums which i know can be custom drilled & tapped, but is it not possible to purchase and fit new 5x112 discs/hubs directly onto my car?
4x130 to 5x112 hub question
Re: 4x130 to 5x112 hub question
It's the rears you will struggle with the most. You could have you rear hub modified to fit 5x112 which will involve welding up the 4x130 holes. Redrill the drum and hub to 5x112. You can't buy off the shelf custom type 3 hubs... To my knowledge anyway.
