Heat exchanger hose?
TheLettingsKid
Post by TheLettingsKid » 30th May 2017 - 11:49am
Hey All,
After nearly selling - I've decided to keep my Type 3. I just love it!
I've had a load of wrk done and now moving onto the rust underneath (sills, etc).
One just I never really finished was the heat exchangers. I had both replaced but the garage couldn't find the right hose to connect the offside exchanger into the heating system for the car. Does anyone know which one I need? A part number would be grand!
I was thinking it might be an "Aluminium Air Hose 60mm X 1000mm" part number 028129087B.
Also, can anyone recommend a good place to buy the replacement sills?
Cheers!
Re: Heat exchanger hose?
Post by broady_6 » 30th May 2017 - 9:53pm
if you have a search on here theres a few post about the "hose" its flexi exhaust hose. No one sells the specific pipe these days, if its an early I believe there was a plastic hose, but for later models its the metal exhaust tube.
This sorta stuff https://www.bing.com/images/search?view ... ajaxhist=0
Its was wrapped in a fibre glass shroud.
