Issues with Solex 32 PHN-1
Hello,
in last days I've disassemble and cleaned my carburetor and I've noticed, that one part is missing.
part with number 40.
Does anybody can measure this part or make close picture, so I can make it new?
Tnx in forward.
BR Samo
mail for pictures: samo.lemez@gmail.com
Tnx in forward.
BR Samo
Re: Issues with Solex 32 PHN-1
The parts book calls it Needle valve rod 5 x 19. Part number 311 129 443. It's no. 66 on the parts book diagram on http://home.clara.net/hallvw/type3/T3pbo/T3pb1-41.htm
Sorry, I don't have that type of carb.
- greenfyregirl
nor me, tho i now have lots of bits from the 32 2/3s
Is this a single carb?
Clare - living in Cheltenham
Yes this is a central single carb. SOlex 32 PHN-1. If you have some for sell and you ship to Slovenia, we can make some deal
- greenfyregirl
sorry- i only have bits from the dual carbs. unless parts are the same?
So I produced new needle valve
https://preview.ibb.co/jEU7sv/image.jpg
https://preview.ibb.co/cTryza/image.jpg
after assembling in carburetor, engine works ok, today I need to go on test drive
Well done. That looks right. I assume it's 5mm diameter and 19mm long ,from the parts book description.
Does anybody have issues with leaking gas on this carb? If air filter is removed, some gas stays in rubber J pipe (between carb and air filter)?
