Hinge pin Removal
Newport1139
Hinge pin Removal
Post by Newport1139 » 7th September 2017 - 1:47pm
I am needing to remove the pins on the top and bottom door hinges due to the top hinges being froze up. They are the (2 bolt hinges). I am curious do these knock out from the top of the hinges or the bottom of the hinges. Hints i am need to the type 3 world! Also if i need to get new hinges where do i get them from?
Thanks,
Re: Door Pins on 72 Squareback
Post by broady_6 » 10th September 2017 - 8:49pm
more of a workshop kind of question. ask in there you might get some helpful eyes see it
Re: Hinge pin Removal
Post by purplepeter » 10th September 2017 - 10:39pm
I've moved it now- Apols for the delay, I've been preoccupied
You might have a read of this to keep you going.. viewtopic.php?f=26&t=1626&p=6272&hilit= ... tool#p6272
