Oil pressure
Aircooled Johnnyo
Oil pressure
Post by Aircooled Johnnyo » 2nd October 2017 - 6:08pm
Does anyone know what the correct oil pressure is for a ‘72 Fasty. Reason for asking is I have added an oil pressure gauge and when hot it seems to be below 10 psi. This seems amazingly low.
Any help is much appreciated
John
Re: Oil pressure
Post by broady_6 » 2nd October 2017 - 6:12pm
10psi at what engine speed?
Aircooled Johnnyo
Re: Oil pressure
Post by Aircooled Johnnyo » 2nd October 2017 - 6:35pm
Tick over speed, without a rev counter I would guess at 800 rpm.
Re: Oil pressure
Post by broady_6 » 2nd October 2017 - 7:11pm
yeah that's fine, the pressure light will come on at 5-7psi. when you curing at 60-70mph you should have over 30psi when hot.
Aircooled Johnnyo
Re: Oil pressure
Post by Aircooled Johnnyo » 2nd October 2017 - 7:24pm
Righto.
Thanks for your help.
I am going to check with a VW calibrated pressure gauge soon, as I’ve heard that the vdo gauges can be used as a guide rather than an accurate measurement?
John
Re: Oil pressure
Post by broady_6 » 2nd October 2017 - 7:29pm
to be perfectly honest I wouldn't worry. have you been having issues with your engine?
If the oil pressure light isn't coming on or flickering. and when you change the oil it isn't full of glitter, there really isn't a need to a pressure gauge. Ive built dozens of these engine and never fitted one, nor have we ever had an oil pressure issue.
Just my 2p
Aircooled Johnnyo
Re: Oil pressure
Post by Aircooled Johnnyo » 2nd October 2017 - 8:05pm
Cheers. It’s just that I did a full rebuild and not done one before. Just a little paranoid I guess.
John
Re: Oil pressure
Post by broady_6 » 2nd October 2017 - 9:09pm
i remember my first build well. i felt much the same, but i put my faith in the pressure light. change your oil at 1000miles and it will tell you if youve done a good job :)
