Fresh Air Box
Jared1969
Fresh Air Box
Post by Jared1969 » 18th February 2018 - 1:29pm
Hi
A few questions regarding my Squareback’s fresh air box, when I turn the fan on it makes a hell of a racket and there is a lot of water on the floor. Have been told if it’s block this can cause the wet floor. If I remove the the unit is it easy to do and refurb. Or is it better to get a second hand unit. Is it also true the seals will need replacing once removed, if so is there a supplier in the UK.
J
Re: Fresh Air Box
Post by sparkywig » 18th February 2018 - 4:27pm
Use Simon Kelley, notch1500 on eBay, for all your rubber needs.
Jared1969
Re: Fresh Air Box
Post by Jared1969 » 18th February 2018 - 11:06pm
thanks, is it a pig of a job?
Re: Fresh Air Box
Post by 937carrera » 19th February 2018 - 1:05am
Have a search of the forum, there's quite a few threads with pictures showing what type of repair might be needed. I know Chino and Kaddy did theirs, but there are others too.
The perception seems to be that they're always worse than thought
Re: Fresh Air Box
Post by kaddy » 19th February 2018 - 11:53am
Broady as well has run the gauntlet on this too. Lots of info there,
and pics too, which are better than thousands of words.
Re: Fresh Air Box
Post by kaddy » 19th February 2018 - 11:55am
Col1600 has done the same repair too
Re: Fresh Air Box
Post by 937carrera » 19th February 2018 - 2:15pm
Ah yes, that was one of the ones I was thinking of but I wasn't sure which of the "blue type 3" avatars it was.Great thread.
