Type 4 411le rear wheel bearings?
jonny rock
Post by jonny rock » 9th March 2018 - 5:32pm
Hi all.
Am I right in thinking that this is the correct rear wheel bearing?
https://www.flickr.com/photos/148106157 ... ed-public/
Timken LM78349 / LM78310A
Other writing on the box
BRG
33
40421
Made in France
Many thanks, Jon
Re: Type 4 411le rear wheel bearings?
Post by 937carrera » 9th March 2018 - 6:07pm
I have some bought a few years ago, never fitted, pretty sure they are Timken, I'll try & check over the weekend
jonny rock
Post by jonny rock » 9th March 2018 - 6:57pm
Thank you, 937carrera
if any other 411/412 members are interested I'v found a UK supplier who has quite a few of these bearings on their shelf's.
Assuming these are correct.
Post by 937carrera » 9th March 2018 - 11:05pm
Right, the brain cells have finally kicked in :)
Have a look at this thread viewtopic.php?f=27&t=5276&hilit=timken
5 years ago and I still have not got round to fitting the bearings, your part numbers are the same that I found so you're good to go. Have you got the seals as well - details in the thread if not. The bearings are readily available, if you buy industrial rather than automotive route. :thumbsup:
richtbiscuits
Post by richtbiscuits » 9th March 2018 - 11:45pm
Jon,
I'd be interested to know where you got your bearings from as my 412 needs the rear bearings doing - the drone is getting quite loud these days!
You got a type 4 over in Walsall? I'm just the other side if the M6.
'72 412 LE Variant
'73 412 LE Variant
'83 1200 Beetle
jonny rock
Post by jonny rock » 10th March 2018 - 1:27pm
937carrera, yep got seals on the way. Unless I'v really cocked up, these are the ones.
https://www.ebay.de/itm/Wellendichtring ... 0723455479
richbiscuits. Yep, in Walsall. My 411le has been fighting me the last couple of years. Various stuff and randomly playing up. Clutch master cylinder went in September last year. Refurbured at past parts. Went to move before recent bad weather and the starters stuck. New bush needed.etc, May have a play tomorrow. Been 18mths since driven in anger! Even the mot guys asking after her, and he hates her.
Bearings.
Bearing Revolution in Telford. I have one bearing and seal. I email pictures and codes over to match and they have them on the shelf.
Here's the link.
https://www.bearingrevolution.co.uk/783 ... ange-34801
Thanks, Jon
richtbiscuits
Post by richtbiscuits » 11th March 2018 - 3:15pm
Jon,
Thanks for the lead on the bearings. I will be getting some ordered up very soon along with some seals. In the meantime I'll see if repacking and tightening up will quiet the bearing down a little.
Sorry to hear your car is playing up. They do tend to do that, don't they. I always seem to get one thing sorted just in time for another thing to go awry. Fortunately they've only been niggling things so far, nothing major. I hope you get your 411 back on the road soon - it'd be great to see another type 4 around the local area.
Regards
Rich
'72 412 LE Variant
'73 412 LE Variant
'83 1200 Beetle
jonny rock
Post by jonny rock » 11th March 2018 - 5:28pm
Jon,
Regards
Rich
No worries Rich, Packing and a tighten up might help.
I had a look at mine today and managed to get her running. Dodge connection on starter. Just got the clutch master cylinder to replace and that's all the mechanical stuff. But I did find some welding to be done, drivers footwell. Which in turn has rotted my accelerator cable tube thing. No idea how to fix that one yet. New post on here. Ta
