Gunson carbalencer
Joe_bury
Gunson carbalencer
Post by Joe_bury » 19th March 2018 - 10:26pm
Hi all,
Just seeing if anyone has a picture of useful tips on the best way to adapt a gunson carbalencer for our solex carbs.
Thank you
Re: Gunson carbalencer
Post by purplepeter » 19th March 2018 - 10:52pm
Cut the top off a road cone or other suitably shaped funnel!
Post by broady_6 » 19th March 2018 - 11:22pm
I seem to recall a 500ml drinks bottle is about the right diameter, coke or spirite ect
Joe_bury
Post by Joe_bury » 20th March 2018 - 3:47am
Great thank you will check out all options here :)
Post by Editor » 27th March 2018 - 1:16pm
I use a section of the large rubber petrol hose with the carbalancer, as It fits the carb tops nicely. However, the owner of my previous twin carb Variant soldered small tubes into the air filter tops above the carbs, sealed with tyre-valve caps. I made a simple U-tube manometer from clear plastic tube, with a bit of paraffin in the bottom. It does the same job as the carbalancer but both carbs can be done together, and under normal operating conditions.
You can check the balance at idle, and as the rpm is increased through the rev range. I found it made a huge difference to engine smoothness, and is easier to use than the Gunson device, as you don't need to remove the air cleaner and throttle rods etc. Much cheaper, too!
Joe_bury
Post by Joe_bury » 28th March 2018 - 10:30am
https://postimg.org/image/qyen5i3if/
Thanks for advice Dave, will look into a twin meter in the future will be more accurate for sure. Came up with this for the time being with a road cone fits like a glove very happy with it. Thanks again
