Rear Brakes
Rear Brakes
Hi a quick question
What rear cylinders and brake shoes are people using on the type 4.
as i need to change a rear cylinder and fit new shoes as i have a leaking cylinder.
Front pads are they the same as T2 ones as these are low on the reading and one is binding.
Re: Rear Brakes
Your front pads are Volvo 240 Rear
Rear shoes are 1302/3 Front
http://www.vwtype3and4club.org.uk/_docs ... rtswap.htm
Re: Rear Brakes
Thanks PPeter much appreciated for the reply. ordered some shoes and a wheel cylinder may have revise Pads as ordered T1 ones from GFS, veewee.
will check out volvo 240 ones
Re: Rear Brakes
In case You don't have it, the gsf discount code this weekend is WKD56
- richtbiscuits
Re: Rear Brakes
Don't suppose you have a recommendation for the discs, do you? Same as 1302/1303?
'72 412 LE Variant
'73 412 LE Variant
'83 1200 Beetle
'73 412 LE Variant
'83 1200 Beetle
- Dave Summers
Re: Rear Brakes
As far as I know they're bigger than any Beetle ones. 411 discs are the same as late Type 3 (1972/73), 412 discs are unique.
Dave
412 Variant
411 2-door saloon
412 Variant
411 2-door saloon
Re: Rear Brakes
Porsche 914
And before You ask, the wheel bearings to go in Your new discs are Mk 2 golf rear
Pad fitting kit is the Volvo one to suit the pads
Re: Rear Brakes
all sorted Volvo 240 a perfect fit, source some rear shoes now have 2 spare sets lol.and some spare pads. Wheel cylinder from a T1front fitted just had to elongate the hole to get mounting bolt in,
thanks for your help, much appreciated,
