ALTERNATOR CONVERSION ON TYPE 3
Pdjordy
Post by Pdjordy » 16th April 2018 - 8:44pm
what are people thoughts on converting the dynamo to a alternator on here? I see there is one available online that I have found has anyone done this
Thanks in advance
Paul
monkeywrench
Re: ALTERNATOR CONVERSION ON TYPE 3
Post by monkeywrench » 17th April 2018 - 11:23pm
Unable to help with the conversion,but where did you find a suitable alternator.
Pdjordy
Post by Pdjordy » 19th April 2018 - 6:09am
The alternator I have found is from calafonia and is around £270 delivered to UK. www.cbperformance.com
Paul
Kai
Post by Kai » 22nd April 2018 - 8:33pm
Mine had a Mazda rx7 alternator converted to fit.
Post by sparkywig » 24th April 2018 - 10:21pm
:cough:
kinga
Post by kinga » 5th May 2018 - 5:27pm
Mine has a Mazda rx7 conversion too...very small alternator & looks a very tidy conversion.(not done by me).
Kai
Post by Kai » 5th May 2018 - 8:50pm
:cough:
My RX7 alternator conversion has found a more deserving home :)
Aaronslimvw
Post by Aaronslimvw » 18th May 2019 - 9:08am
I have done the conversion successfully using a daewoo matiz altenator.
muddy
Post by muddy » 27th August 2019 - 7:35am
Do you have any details on your conversion? I might look at doing this over the next winter. :D
Instagram: @type3.fastback
s.unsworth
Post by s.unsworth » 27th August 2019 - 8:45am
Why ?
What is wrong with a Dynamo ?
Post by broady_6 » 27th August 2019 - 5:47pm
You can do it with a beetle one. I'll show you some photos later.
Theres nothing wrong with a dynamo. But if you start running higher power audio equipment and other electrical stuff, the drain on the battery is greater than the dynamo can replace
Post by sparkywig » 27th August 2019 - 8:04pm
I'd like to see the beetle alternator conversion please.
Post by broady_6 » 27th August 2019 - 10:19pm
Better photos on order, I saw how he did it. The reward section is the same diameter as a dynamo. So it fits nicely and keep the armature and pulley on the same axis. Thus a type 3 belt will still fit. He then clearanced the housing and modified a beetle dyanmo clamp.
Post by sparkywig » 28th August 2019 - 6:22pm
Oh, that's not how I thought it was going to be fitted.
On TheSamba.com there's a thread about alternator conversions and someone posted this.
muddy
Post by muddy » 28th August 2019 - 7:23pm
Thanks guys, that'll keep me busy over winter.
Now that the cars alive now, 2020 show season becons and my audio install is on the list to do, alternator is a must (even if I've got 2 batteries and a split charge system).
I'll update my build thread when I do it. :D
Post by broady_6 » 28th August 2019 - 10:33pm
How were you expecting to see it? More food for thought
Oh how weird, as i posted that the photo appeared and it all become clear!
Aaronslimvw
Post by Aaronslimvw » 3rd September 2019 - 10:27am
Why ?
Reason i switched to an alternator is because i am running air ride on my fasty, using x2 compressors.
Post by broady_6 » 3rd September 2019 - 10:17pm
Ive got more photos, just been very busy. Will try and get them posted tomorrow
Marko
Post by Marko » 7th September 2019 - 4:31pm
I did it! was quite easy and cheap to do.. just need to adapt a strap and grind a bit of the case way for it to sit straight in.
Mark.
viewtopic.php?f=4&t=6896
muddy
Post by muddy » 11th September 2019 - 9:16pm
Mark.
Hey Mark, do you have any more details on the alternator itself; model number? Also any pics of how it's installed, any special metal work needed for brackets? How much did you need to remove from the fan housing? Just weighing up my options (and cost).
Cheers :) :) :)
Post by sparkywig » 12th September 2019 - 10:56pm
Apparently a Metro alternator bolts straight on. Just waiting for more details and pics.
Post by broady_6 » 15th September 2019 - 7:12pm
Right its taken me some time, weve had some internet issues at home for nearly a week. Namely someoe helpful company cut down our phone line.
All credit goes to moler, for carrying out the mod and sharing the photos
https://1drv.ms/v/s!AusvA9cWpa_XgabqOv_-Lc4Wj-fg4ys
muddy
Post by muddy » 16th September 2019 - 8:26pm
@ Broady. That's the beetle set up i guess? That's too much metal work and removal for me. I might just opt for this
https://www.ebay.co.uk/itm/VW-TYPE-3-55 ... %7Ciid%3A1
Post by broady_6 » 16th September 2019 - 8:58pm
Yeah thats a type 1/2 alternator.
If youre planning go that route, it can be done much cheaper, thats generic universal alternator. Ive used it on a few things. Ill get the details off the box tomorrow. But a quick googles brought uo this
https://www.carbuilder.com/uk/compact-l ... alternator
