Hi everyone
Can I use a 66 type3 vaccum advance distributor on a 71 engine? its not fuel injection...
thanks Clare
distributor question
- greenfyregirl
Clare - living in Cheltenham
Re: distributor question
Yes you can more or less use any air cooled distributor on any air cooled engine. But it may not run as smoothly, efficently or cool as it would with the original spec. If you are replacing an SVDA with another SVDA from a carburetor engine and manual car, you should have little issue if any at all.
- greenfyregirl
thanks, it says it belongs to a 1966 1600tl, so it should be close..
is it an Single Vacuum Dual Advance? I assume thats what you are removing?
- greenfyregirl
ah yes, but thats not original and theyre crap any way. The SVDA youre fitting will be much better
- greenfyregirl
