Ignition problem
Rob 400e
Ignition problem
Post by Rob 400e » 26th June 2018 - 8:29pm
I have electronic fuel injection on my 411 le, I managed to leave the ignition switched on for eight hours !!! Oh dear. I tried to start the car which normally starts first time on the button, it just turned over. I touched the coil which was at melting point so I assume I've fried the coil. Would I have damaged the whole electronic system?
Re: Ignition problem
Post by broady_6 » 26th June 2018 - 9:54pm
It's more than likely you have nailed it. The coil has over heated, does the fuel pump still run?
Post by 937carrera » 26th June 2018 - 10:14pm
It doubt it will have been on for 8 hours, the battery probably went flat before then. I'd agree coil will be burnt out, I wouldn't expect there would be other damage. Fingers crossed.
Rob 400e
Post by Rob 400e » 27th June 2018 - 12:30am
Will check to see if I have fuel pumping tomorrow and check for a spark. I can live with changing the coil and fuel pump fingers crossed I haven't trashed anything else. And yes the ignition was on for eight hours and it still turned over no prob.
Post by 937carrera » 27th June 2018 - 11:04am
Well that is a surprise............ I suppose now I'll have to admit doing the same thing, flat battery but coil still absolutely fine. Figure that out, I can't.
Post by 937carrera » 27th June 2018 - 11:23am
I've sent you a private message Rob (top right to see it)
miketyp3
Post by miketyp3 » 27th June 2018 - 4:55pm
Points open / points closed?
Post by 937carrera » 27th June 2018 - 5:54pm
Hmm, now that's an interesting question, the answer to which is of course that I don't know.
Points open = no circuit for LT side, so no EM field in HT circuit and no coil damage ?
My running one is an LS so no fuel pump relay etc to worry about
Better to be lucky than good :)
Rob 400e
Post by Rob 400e » 27th June 2018 - 7:41pm
Well folks all is well in my world started the car this morning it started first time on the button. I cannot believe my luck. Will be investing in a new coil however don't really trust this one it was well fried yesterday so hot you couldn't touch it. There you go.
Post by broady_6 » 27th June 2018 - 10:10pm
I do enjoy the technical depth on here!
:thumbsup: :thumbsup: :thumbsup:
