clutch cable
greenfyregirl
clutch cable
Post by greenfyregirl » 2nd July 2018 - 1:50pm
do i need to take off the pedal assembly to chsnge the clutch cable? my adjuster wing nut is rusted on to the old one...
Clare - living in Cheltenham
Re: clutch cable
Post by broady_6 » 2nd July 2018 - 1:55pm
It can be easier, but it is possible to do it without removing the assembly, But you will have to get that wing nut off before you can do anything else, unless you just plan to cut the cable
greenfyregirl
Re: clutch cable
Post by greenfyregirl » 2nd July 2018 - 6:27pm
I cant seem to find a hook on the pedal- like the jon muir book says.
So where is the cable at the pedal end attached?
Re: clutch cable
Post by broady_6 » 2nd July 2018 - 8:03pm
Inside the tunnel. I assume your RHD. in which case take the plate off the side of the tunnel on the passenger side. Remove the throttle cable lever and then two 17mm head set screws from memory. Then remove the pedal stop on the drivers side to allow the clutch pedal to fall to the floor, that should unhook it. id advise removing your carpets as the old cable will likely have grease on and make a mess if you slip ect.
