oil cooler replacement
greenfyregirl
Post by greenfyregirl » 14th August 2018 - 5:09pm
Hello
Im slowly putting my engine back together and have got to the oil cooler.....Ive got three questions!!
My haynes manual says to remember the spacer plate- where applicable- what does one look like?
Do i need foam all round the cooler?
and should it be the thick or thinner seals??!
Clare - living in Cheltenham
Re: oil cooler replacement
Post by broady_6 » 14th August 2018 - 5:48pm
The spacers are just three thick washers.
Item 8
Yes you need the foam, its to force the cooling air to go through the cooler.
Use the seals which are the same diameter as your oil ports. I would expect 10mm. Usually the thick ones as the the thin ones are too thin to seal up
greenfyregirl
Post by greenfyregirl » 14th August 2018 - 7:21pm
Brill thanks!
that will help loads. are the washers metal?
and is the foam all the way round? and do i need the bit of what looks like tinwear in the second pic???
Post by broady_6 » 14th August 2018 - 9:31pm
Yeah metal washers, ive got a set in the garage. ill go measure the thickness shortly for you. The foam is just on top. Im not sure what that bit of tin does, but VW wouldnt have put it there just for the hell of it. Though im sure plenty of cars are running without it these days
madmatt
Post by madmatt » 15th August 2018 - 12:10am
there was an amendment i remember about not using the spacers with the green seals
greenfyregirl
Post by greenfyregirl » 15th August 2018 - 8:28am
Thank you :) I asked about the bracket because i havent got one.
Post by broady_6 » 16th August 2018 - 8:11am
2.5mm thick
greenfyregirl
Post by greenfyregirl » 16th August 2018 - 11:31am
thank you :)
