which fuse?
Jamesq123
which fuse?
Post by Jamesq123 » 11th September 2018 - 6:29pm
hi guys was just wondering which fuse is it or what do i need to get for my rear brake lights? both have stopped working, when i put my head lights on the rear bulbs light up but when u press the pedal they dont come on. any ideas?
Re: which fuse?
Post by sparkywig » 11th September 2018 - 8:28pm
Could be the brake light switch on the master cylinder.
Take the two cables off the brake switch and connect them together, if the brake lights come on then it's the switch that's faulty.
If not, it's the fuse/cable/connections.
Dave Summers
Re: which fuse?
Post by Dave Summers » 13th September 2018 - 11:02pm
Doesn't sound like a fuse. Are the dual-filament bulbs in the rear light units fitted the right way round? Sounds like it could be that the headlight circuit is connecting to the brake light filaments and the brake light circuit trying to reach the tail light filaments but not managing because the bulbs won't be seated properly. Or it could be bad earths, which can do strange things - most likely near the light units. Worth checking the wiring at the fuse box and on to the headlight switch too.
Dave
412 Variant
411 2-door saloon
Re: which fuse?
Post by 937carrera » 13th September 2018 - 11:48pm
http://home.clara.net/hallvw/wire66tl.htm
Any help? looks like fuse 9 on that year.
Do what Sparkywig has suggested as a quick diagnostic
Jamesq123
Re: which fuse?
Post by Jamesq123 » 14th September 2018 - 8:35pm
Thanks guys...will have a check over the weekend
