Hi, I need to replace all the copper brake pipes on my 69 us import fastback.
Does anybody know the correct size diameter of copper brake pipe I need?
Aaron
69 Fastback Copper Brake Pipe Size
Re: 69 Fastback Copper Brake Pipe Size
3/16 is the correct size. They were originally steal pipes, though for standard brakes a copper replacement is much better. I coat mine with grease every year to prevent corrosion
Thank you broady6 much appreciated.
Different quality of male and female fittings too.
lesser quality fittings have sharp coarse uneven threads.
Good quality fittings have a smoother type thread, that work nicely
into wheel cylinders ect.
