Type 3 twin carb air filter set up
Post by broady_6 » 23rd December 2018 - 5:05pm
Me again,
So i need to set up the warm air intake on the air filter. The bentley manual doesnt cover this as thats for the FI engine. I have had a look all over this site and the samba, along with a good googling too and come up short. I assume you adjust the tension on the spring here.
Until the flap in the intake end is at a certain gap when its all cold. Does anyone have the procedure for setting this up?
Re: Type 3 twin carb air filter set up
Post by kaddy » 23rd December 2018 - 5:32pm
According to the Haynes manual.
See 3 and 4.
Forgive the quality.
Post by broady_6 » 23rd December 2018 - 5:52pm
Cheers, thats a good starting point, i assume theres no mention of how to set it up if you have to change the thermostat? I guess its no that critical. Maybe just needs to be fully open when the thermostat is a full extension?
Post by kaddy » 23rd December 2018 - 6:25pm
Would assume that its fully closed, and only opens when the temp hits 45c.
It appears to me its either closed or opened, and nothing else.
No other mention of this at all in the manual that I have come across.
Post by kaddy » 23rd December 2018 - 6:59pm
Just checked Peter Russek pocket manual for 1500/1600
Nothing their either.
Post by broady_6 » 23rd December 2018 - 7:04pm
Yeah I think were both along the same lines. I will have a play tomorrow and see what the range of travel is like ect
Post by kaddy » 23rd December 2018 - 10:07pm
You probably already found this, its the thermostat on the oil bath cleaner on
a beetle. Might help
https://www.thesamba.com/vw/forum/viewt ... ?p=4681758
Post by broady_6 » 23rd December 2018 - 10:27pm
I hadnt found that, But I will no have a read thank you!
Post by kaddy » 24th December 2018 - 3:00pm
This is another one I found yesterday and tried to post, but I think some gremlins appeared at the time,,
https://www.thesamba.com/vw/forum/viewt ... highlight=
