Good News ! ... :) ... You can now post photos directly to the forum, for more information please read the announcement Forum Improvements phase 2
Wiring in a hazard warning switch
kamikaze notch
Post by kamikaze notch » 29th March 2019 - 10:25pm
Sonic would like to wire in a hazard warning switch into my 1968 notchback I have zero clue where to start, I do have what I believe to be the correct switch so my question is.... Where do I go next any help and advice would be appreciated as really don't know what to do I just really want hazards after the last time the notch decided not to work!
Re: Wiring in a hazard warning switch
Post by broady_6 » 29th March 2019 - 11:00pm
If you have the correct switch, surely it just a case of mounting in the dash and connecting the wires up as per the wiring diagram?
This diagram should show everything you need, pin numbers and colours ect.
https://www.thesamba.com/vw/archives/in ... 3_6870.jpg
kamikaze notch
Post by kamikaze notch » 30th March 2019 - 1:01am
That's all great but it's never had a hazard switch fitted before so where do I start, I am no car electrician and don't want to trash what's there already!
Post by broady_6 » 30th March 2019 - 10:05am
Since you've owned it? Or ever? Id expect it did have originally. So hopefully all the wiring is there behind the dash.
Whats the part number on the switch you've got?
If youre starting from scratch, the first thing to do is work out where on the dash youre going to fit is, as this will determine the lengths of all the wiring.
You can see the standard position for later cars here.
kamikaze notch
Post by kamikaze notch » 30th March 2019 - 11:23am
It has never had one... My notch is a '68 so the layout is a little different and I would have to drill a hole between the ashtray and clock.
The switch I has a part number of 111953235F seven pin unit
Post by 937carrera » 30th March 2019 - 8:46pm
Can you read / understand the wiring diagram broady posted ? (you're new we don't know how experienced you are)
kamikaze notch
Post by kamikaze notch » 30th March 2019 - 10:18pm
Not the best at electrical stuff that's for sure.... but with a little guidance I will be able to get it figured
kamikaze notch
Post by kamikaze notch » 30th March 2019 - 10:20pm
Also where is going to be the b at place to buy sell of the correct colour coded wires?
Post by 937carrera » 30th March 2019 - 11:15pm
Local motor factors / car accessory shop will likely be best, but you will only get a variety of colours, not necessarily the right ones. or ebay
Post by broady_6 » 30th March 2019 - 11:53pm
Ive got some old loom off cuts, its depends which you need and how long?
Id guess Black/Green
Black/White
Black/Whitegreen as a minimum
It'll depend what wiring you already have. I suspect you car could be a 67 model though?
kamikaze notch
Post by kamikaze notch » 1st April 2019 - 12:39pm
Yes that would be perfect.... My notch is a 12v '68 and the wire colours you have listed above are what my workshop manual wiring diagram lists also, 0.5mm Brown, 2.5mm red 2.5mm white and 1.5mm blue, if you have those cuts spare too that would be awesome!
Many thanks.
Post by broady_6 » 1st April 2019 - 1:19pm
I'll have a root around this week, what lengths do you require?
kamikaze notch
Post by kamikaze notch » 1st April 2019 - 8:46pm
Awesome that would would be superb man thanks!
Don't really know on the lengths to be 100% honest man, I plan on mounting the hazard switch between the ashtray and the clock..... So as much of each colour as you can spare would be perfect as I don't know exactly the lengths plus possible mistakes if I make them!
Post by Editor » 6th April 2019 - 1:11am
Warning: Disconnect battery before you start!
kamikaze notch
Post by kamikaze notch » 6th April 2019 - 2:20pm
Hehehe.... Yup did that already! 😁
Post by broady_6 » 6th April 2019 - 3:52pm
just dug me boxes of wires out and looking at your shopping list. ill be in touch shortly
