External oil cooler location
Post by sparkywig » 19th May 2019 - 12:16pm
Hello all.
Any of you running external oil coolers above the gearbox, can you post some pics please?
Thanks.
Re: External oil cooler location
Post by broady_6 » 19th May 2019 - 1:11pm
I don't have one installed. But I mocked one up for the bigger engine I had planned to fit before I saw the body rot. It was along side the gearbox, forward of the drive shaft with a rough tin scoop to duct air into it. The brackets triangulated on the gearbox side plate studs
Post by sparkywig » 20th May 2019 - 8:43pm
Not much room there though, how did you mock yours up?
Post by broady_6 » 20th May 2019 - 9:47pm
I had quite a small cooler. layed over flat with the elements facing the ground rather than the direction of travel. Havent got access to it at the moment but it was about 8 in x 3 in from memory.
Post by 937carrera » 20th May 2019 - 10:21pm
I think I read somewhere that an angle of about 35 degrees works quite well for allowing air to pass through the cooler, without generating too much drag. I think that's the reason for Ginetta G50/55 radiator design.
On the other hand, a couple of coils with aircon type fins will probably prove to be quite adequate
Post by sparkywig » 21st May 2019 - 10:32am
I think I'll go with a smaller cooler rather than the 36 row pictured. Then it can be mounted at an angle under the heat exchanger and ducted.
Post by purplepeter » 21st May 2019 - 8:02pm
Speak to Angelo Amato- I think He has an external cooler
Kai
Post by Kai » 26th May 2019 - 4:07pm
That cooler is massive!
The one previously had fitted was attached to the rear beam with a bracket and duct. Was 1/4 size of that though.
