Big oil leak
Aaronslimvw
Big oil leak
Post by Aaronslimvw » 23rd May 2019 - 10:52pm
Hey, my late fastback has developed a big oil leak. It looked like it was from the oil cooler. But on further inspection the oil was spraying up through the fan shroud and under the alternator and under the tins towards the oil cooler (thus making me think it was the oil cooler leaking).
Oil absolutely everywhere, have ran the car without the tins onto make sure. Anyone else experienced this??
Re: Big oil leak
Post by sparkywig » 24th May 2019 - 12:42pm
Is it coming out from the crank pulley?
Are you running the stock air filters and breathers?
Aaronslimvw
Re: Big oil leak
Post by Aaronslimvw » 24th May 2019 - 7:55pm
Stock air filter yes, breather box was ruined so just had a pipe going from one head to the other, without the breather box in the middle
Dave Summers
Re: Big oil leak
Post by Dave Summers » 24th May 2019 - 8:18pm
Have you checked the pushrod tubes? Could be as simple as a rusty tube or failed seal.
Dave
412 Variant
411 2-door saloon
Re: Big oil leak
Post by purplepeter » 24th May 2019 - 8:21pm
So what's in place of the breather box then? Is the tower just gaping?
Aaronslimvw
Re: Big oil leak
Post by Aaronslimvw » 24th May 2019 - 10:19pm
Tubes look ok, breather is now just a pipe from one head to another.. but will change this so they go into the air box as they should
Re: Big oil leak
Post by broady_6 » 25th May 2019 - 11:43am
That should cure it, you need the crank case connected to the intake as its the vacuum from the intake that stops the case from over pressuring
Aaronslimvw
Re: Big oil leak
Post by Aaronslimvw » 28th May 2019 - 7:58pm
Done that, but now the thing wont start! I must have disturbed something. I will investigate further this week and let you know how i get on.
Thanks for the replies !
