OK hive mind, I need your assistance again.
Basically I've fucked up. I've swapped the new gearbox in along with a short axle conversion, and now I can't get the 944 discs or original '67 drum brakes to fit due to the shorter splined axles.
So what brakes can I fit with no (or very little) modification, or do I bite the bullet and get a CSP swing axle rear disc conversion.
Thanks in advance.
Rear brakes
Re: Rear brakes
Forget the brakes, I've bought the CSP kit.
