Gasket Set
Gasket Set
I am looking for a pic of a type 3 gasket set that also has the description of each individual gasket. I know I've seen this before but cannot now find a copy.
Don
Don
Re: Gasket Set
Ive never seen one for everything, but I know there are some on the samba. Which gaskets do you need help idenitfying? I can help.
Re: Gasket Set
Hi, It's the engine gasket kit and it has all the gaskets numbered then the descriptions for each number listed below. It may have been someone from the Type 3&4 club or the Samba who created it. It's very handy when you don't require all the gaskets in the kit and where there are similar gaskets e.g. oil pump Etc.
Re: Gasket Set
Yes I understand that, I know what all the gaskets are for. If you let me know which ones you are struggling with, I can indentify them for you.
Re: Gasket Set
For the Oil Pump, You'll have 2 different sizes of stud holes for both the base & cover- it's fairly self explanatory- whatever size fits your studs
Oil cooler- Measure your oil ports on both Cooler & Crankcase
One part you won't find in a set is the oil filler gasket- You have to make your own
For manifold gaskets to Head, I personally prefer the Twinport fibre gaskets available seperately
Re: Gasket Set
Thanks guys for your help and suggestions e.g. the twin port gaskets. I have now found the pic of the gasket set I was looking for https://www.thesamba.com/vw/gallery/pix/1129361.jpg
Re: Gasket Set
Glad you found what you were looking for, I have the manifold gaskets available. Along with carburettor ones
http://www.vwtype3and4club.org.uk/forum ... 0a33b0a21e
Re: Gasket Set
I found the oil filler tube gasket in my box of gaskets, it looks like it came with a set. I can get some made if we need a supply though?
Re: Gasket Set
Try offering it up to an oil filler pipe!- size of the hole doesn't line up
It's not rocket science to make as & when needed & most people would have some gasket paper knocking around
Re: Gasket Set
I guess it depends what brand of kit you buy, this is an aceptable fit. From the Elring kit.
