Picking up dirt from somewhere?
Is your overflow/filler vent hose letting muck in? They crack and let muck in from the road.
TYPE3 MISFIRE
- SQUARY SPICE
- Contact:
Hi Squarey!
A couple of weeks ago, I had very similar symptoms. Black exhaust. Struggling to idle, but ok at speed. Also difficult to restart after a couple of minutes of being shut down.
I had a nosey down the carbs and saw fuel dripping in. I checked the fuel pressure and it was about 6psi - should be about half that. I tried adding extra gaskets as per the manual to reduce the pressure. I added 3 or 4 and had only slightly reduced fuel pressure. So I popped another pump on. All fine now
With your very high CO, black exhaust etc - this might be worth checking? I think you've changed just about everything else anyway!
Good luck with it!
Good luck with it!
Gary Miller
Barrow-in-Furness
[url]http://www.furnessvw.co.uk[/url]
[img]http://i111.photobucket.com/albums/n155/gmille46/T34/T34.jpg[/img]
Barrow-in-Furness
- SQUARY SPICE
- Contact:
cheers bud will give it a try,i ve a spare fuel pump tp try,plus ive borrowed yet more solexs to try....cheers hotrodfreak,if i make it there ,the coffees on me
SQUARYSPICE back to 89 old skool
www.demondubs.com the new online vw home
[url=http://www.demondubs.com][img]http://img257.imageshack.us/img257/1116/mybannerblinky456e09ef0.gif[/img][/url]
Think i may have caught it from you on sunday!
Drove to work yesterday, went to go home and couldnt beleive it
struggling to idle, black exhaust, but ok at speed!
got home and had a look around nothin i could see apart from the
1/4 tank of fuel gone, got it booked in at M.A.C. tomorrow!
Fingers Crossed!
Fingers Crossed!
