Hello, I'm Pedro from Spain. I don't have a type 3 or 4 but I think you could help me.
I've a 1980 T25 transporter with ct 1600cc engine (very similar to a type3 engine).
Two years ago I completely rebuilt the engine with the following parts:
76mm Crankshaft
85mm cylinders (it makes 1750cc with the 76mm crank)
Standard dual port heads
I set the compression ratio to 8.5:1
I kept the original center-mounted carburettor (Solex PICT-4 34mm)
The engine runs OK but I think it could go better.
Do you think it’s a good idea to put a dual Solex 34 kit or Weber ICT 34?
(I would need a type3 kit to keep it under the deck)
