Right then, I have got an oil leak on the Notch and have been advised it is more than likely the camshaft core plug in the crankcase, which means engine out, tinware off, split the case etc.
Whilst I am at it I intend to swap out the tinware I currently have fitted with some better condition stuff, however, I am not sure it is all there as I was offered it cheap by someone who couldn't confirm it was all there.
So my question is, can someone post up a pic of a exploded view of the tinware.
I can then cross check this against what I have.
Notch Leak leading to tinware question.
I've finally seen the light. Well, 2 lights, 2 6v lights on the front of a 64 Notch!!!!
Re: Notch Leak leading to tinware question.
This may help. It's on the Technical website.
http://home.clara.net/hallvw/type3/T3pbo/T3pb1-36.htm
Some bits won't apply to yours - but it may help get the picture. I can look up any specific parts if you want to check.
