hi will the plastic chrome trim insert that comes on a roll fit into the rear screen of a 64 notch ? ive got some leftover from my deluxe bay window including the joiners, or is it like the ghia stuff c shaped and t shaped trim ?
cheers in advance . steve.
oh just bought the notch a 64 swedish import a few years back in safari beige . im told it used to belong to ivan ?
64 notch rear screen trim
Re: 64 notch rear screen trim
I'm not sure if it would fit or not, but the type 3 stuff is a "C" shaped profile.
It's also best fitted before the screen goes in rather than used to expand the seal like other inserts.
hi mate thanks for the reply , the c shape stuff is the same as the bus alli insert profile so i recon it will fit , cheers just wanted to make sure before i needlessly removed the rear screen . . .will deffo do it the way you advised cheers steve
If it fits let us know where you got it from, it might be of use to others.
