topnotch
Post
by topnotch » 7th June 2006 - 8:59am
As the subject says really - if later ones are IRS, what year did they change?
Only asking as i think my gearbox is on its way out - lots of whining - sounds like its in reverse when going forwards, etc. I`ve changed the transmission oil and added an additive but with no real luck.
Also, will a late transmission fit an early type 3? mine is a 1964 1500s running a stock engine.
by the way, if anyone is going to bristol volksfest on sunday and has a spare transmission in good condition for sale, let me know.
edit: also just thought - what about flywheels and clutch? mine is 6volt at the moment - will my 6 volt flywheel and clutch fit a later transmission?
thanks ,
mike
miketyp3
Post
by miketyp3 » 7th June 2006 - 11:40am
You'd be looking for 67 or earlier to get a swing axle box, but 66/67 will have 4 stud drums. Flywheels have a different number of teeth, but are all the same size from 63 on, so you shouldn't have any clearance problems.
Mike.
topnotch
Post
by topnotch » 7th June 2006 - 11:42am
could i not swap the 5 stud axles over to the later transmission?
miketyp3
Post
by miketyp3 » 7th June 2006 - 1:39pm
Yes of course, but if you didn't want to, you'd need the earlier one.
I didn't mean to confuse.
Mike.
miketyp3
Post
by miketyp3 » 7th June 2006 - 1:40pm
Actually... you wouldn't need to change the axles, just the brakes.
topnotch
Post
by topnotch » 7th June 2006 - 2:00pm
thats interesting - i didn`t realise that i could swap all the brakes over - i.e backing plates, drums , shoes etc over.
thanks for info - i`ll keep a lookout for a type 3 swing axle box,
cheers,
mike
