Upper trailing arm seals
- Creationblue
Hi are these the same as beetle ones? I don't seem to have any
Just
Just
Re: Upper trailing arm seals
This shows what you should have - O-ring for the top. Plastic sleeve with embedded metal flange for the lower.
http://home.clara.net/hallvw/type3/T3pbo/T3pb4-6.htm
- Creationblue
Where can I get them?Editor wrote:This shows what you should have - O-ring for the top. Plastic sleeve with embedded metal flange for the lower.
I don't know. It's listed as a Type 3 part. 311 405 129A. It's basically a thick O-ring that fits on the torsion arm. I don't know if the Beetle has them. I might have one to measure. They're probably about 4-5mm thick, from memory. Maybe someone has one handy to measure.
http://www.type34.com/blogs/latest-blog-posts shows sme o-rings to give you an idea.
I've just noticed the parts book lists the thrust ring for the upper torsion arm on a different page and diagram - I've no idea why they did that. The upper needle bearing is 44mm diameter, so you're probably looking for an O-ring with internal diameter 44mm and thickness around 4mm or so.
http://home.clara.net/hallvw/type3/T3pbo/T3pb4-2.htm
- Angelo Amato
bottoms are same as type 1 beetle (seals and needle bearings)
tops are type 3 specific, consist of a metal/plastic bush you have to knock in, also there is a rubber 'o' ring. top needle bearings are type 3 specific.
from experience, the top bush and needle bearings are like rocking horse doo doo to get hold of, rubber 'o' ring, you could prob get a generic one to fit.
angelo
angelo
- Creationblue
thanks guys, I see there is a pattern emerging here
I have NOS top (thrust) bushes if you need them.
Agreed, the top "o ring" type seal just seems to float, so something generic should work.
In any case, I have a NOS pair at home I can measure.
Unless they are rusty or damaged the needle bearings are not usually a problem.
The bearing surface on the trailing arm seems to be what wears.
- Creationblue
Mine are missing and it appears the beam is greased, the inner bearings are in good shape but wont stay that way unless I can keep said grease in the beam, so I assume its just the seals I need
The upper seals are available from ISP west, so its worth ringing round Karmann connection & coolair to ask which of them is closest to placing an order. Heritage might be worth a shot too,but I understand they wait 'til they've got £500 worth of stuff to order,whereas kk & coolair just order on a regular basis.( if those fail,gimme a yell,as theres a Bristolian vw fan in the states at the mo & i'm sure he'd whack a pair in the post)
Lower seals are available from Heritage
I had hoped to find my seals to give you a photo & dims,but theyre hiding at this precise moment!
I may have a pair if used upper seals. Will check and could post with the master cylinder pushrod if still needed
Lee
Lee
- Creationblue
leec wrote:I may have a pair if used upper seals. Will check and could post with the master cylinder pushrod if still needed
Lee
I'll let you know about the pushrod when I get to the MC, keep the seals for me tho
Just
