Hydrulic system
Hydrulic system
Well, the clutch master cylinder is leaking slightly from the front seal, and the brake master cylinder has gone a little 'soft'.
They both still function, and a flush bleed and change of fluid helped a little, but definitely a rebuild is on the cards soon. I think they will not need any machining, just new rubbers.
The question in, is it possible to get rebuild kits for these? I looked at the parts interchangeability table and it says brake master rebuild kits are unavailable and doesn't even mention the clutch cylinder.
Failing that, what do i do? Im sure another master cylinder can be made to fit if necessary (shame thers not much room there between the firewall and gas tank, or i would hack a hole through and fit a golf servo and master and run a 10mm copper pipe to the engine bay for vacuum). I guess clutch cylinders are pretty generic and almost any can be made to fit as long as you still match the master/slave ratio and the throw of the slave cylinder.
But i dont want to do anything drastic like that if its possible to just rebuild these ones.
Any ideas?
Any ideas?
Death to FF!
It seems that these components are rare, and the places that sell them, sell them for real money, and thats for people with real jobs. And also for people who can wait for the cylinders to be rebuilt and sent back, which i cant.
By the way, the chevette is taxed and MOTd now, but i hate it. Its on ebay. Maybe it will pay for some tidying of the 411.
Im going to go measure the throw of the clutch pedal, and see if i can make some master/slave combination from another vehicle thats easily available fit.
As long as the slave cylinder has sufficient throw to activate the clutch properly, everything else can be made to fit. If its metric, even all the pipe threads are likely to be the same.
Will update if i manage to come up with anything.
By the way, just so im not missing anything, in 411s the clutch is fed from the same fluid bottle as the brakes right??
Death to FF!
- TYPE IV estate
I think unfortunately the bores are pitted, new seals will not help.
The brakes are kind of ok, a little low down, but some new fluid and a bleed will no doubt help as they probably have 30 yr old fluid.
But its the clutch thats nearly gone, and it feels like its bore pitting rather then anything else.
Death to FF!
- TYPE IV estate
Ifyou're after RHD Type 4 brake master cylinder, Jim Bourne has some (I'm sure he hasn't sold them all yet). Probably around £60. 01273-400463.
For the clutch, you could ask him if he has any info, but may be able to find where to get a seal from if he can't help from Jane and Bryan. 01303840374.
Re: Hydrulic system
For info, Jim's sold all of his brake master cylinders - so that he doesn't get hassled by people like me in future!
Kieron
Re: Hydrulic system
Right. That should be about 8 Type 4s still on the road then that wouldn't have been!
Re: Hydrulic system
Just received my reconditioned brake master cylinder from past parts. It took them about two weeks to turn it around. £108 all in. They have inserted a stainless liner and put new seals, including the end cap. It's back in and now needs bleeding so can finally get the MOT done.
Seems like a good deal to me.
Kieron
Kieron
Kieron
