412 automatic firewall tinware
- hernandez412
Is the tinware on the 412 auto different, in that it has holes to access gearbox bolts, line. I've got a baywindow one will this do if modified. Atlernatively pictures of the engine bay at the back so I can fabricate something up. Finnished welding and painting Frankensteins heatexchangers, nasty job only 2 exhaust studs to weld out of the heads, there snapping and getting shorter with every sheared, welded nut. More release oil and a night off I think
