HELP PLEASE!
HELP PLEASE!
I hope someone can help me as i have scratched a hole in my head...The problem i have is that the bonnet release cable on my 411 variant has slipped off the catch and i can no longer unlock the bonnet to open it, any ideas on how i can get access to the catch?
"A BLIND MAN WOULD BE GLAD TO SEE IT"
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
Re: HELP PLEASE!
Try taking the headlights out and put your arm thro the hole and undo the catch with your hand.
The solid cable should be bent over after the clamp to stop this happening.
Good luck
Ron
Good luck
Ron
Re: HELP PLEASE!
HELLO,,now you have a small bad expérience with the wire,, but ,, for the future, put a second wire with handle behind the lite housing,,
Re: HELP PLEASE!
or if we suppose you got an accident on the rear of your car,, on wagon,, it is impossible to open the rear hatch,,cover,, i have a secon wire but mine is in the motor section,, i have just drill a hole ,,small hole for to pass a stell wirer,,connected on the ketch,, with an handle,inside , in case,, we never,know,, ,
