Glass Dimensions
Glass Dimensions
Please could someone volunteer to supply me with dimensions of 412 & 411 glasses-windscreen,rear screen & side glass,to assist identification of parts in the collection we're sorting out?
we moved 6 or so side panels from the attic yesterday,but no idea what theyre off!
Easiest way to do it is probably to measure to the trim edges
Cheers,
Peter
Cheers,
Peter
Re: Major collection
I will measure up my 411 windows as best i can for you at the weekend and post the measurements up on Monday when i have internet access again.
Cheers Mart
Cheers Mart
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
Re: Glass Dimensions
This was the best i could do on my own i will try and get the front windscreen dimensions when i can enlist the help of one of my mates.
I hope this is of some help.
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
Taken a while to do this as I forgot and was reminded by Arcane posting his sizes.
As his is for a 411 Variant thought it might be interesting to compare window sizes just in case they are different
The rear most side window has a very slight taper to it dropping about 10mm along its length...thought it was my bad measuring till I lookd at Arcane's and he notes the same taper
Fantastic!
Well Done & thanks to both of you!
I'll print it & take it with me at lunchtime,so we can get some glass listed tonight!
& i'll speak to dave about archiving the info along with type 3 dimensions-would be jolly handy to have it as a reference
I forgot to add that the measurements i took were from the outside edges of the chrome trim inserts.
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
and mine where to roughly the inside edge so that could explain some of the variations
Just to confirm the rear window glass is the same for 411 and 412, and obviously the rubbers too.
This needs putting in the section on interchangability of parts, no?
I think I would have expected the 411 and 412 Estate to both have the same window glass. I was really only confirming the separate measurements taken were different because of where the guys had measured to.
hello,,DAVE,, i d,t can said if all the glass for the 411-412 are the same,,but wend i look on the net,, for ,,origlass,,italy,, they geeve in her catalogue,, the same pn. for the 411-412,, for sure in europe on the 411 for the front door glass with the small vent glass the big front door glass is différent,,with the 412,, but for the rest i thing they are the same,,
patience and patience with a 412
