Eberspacer timer wiring?
Just for 411 and 412 stuff.
shawn71
Post by shawn71 » 10th March 2011 - 5:40pm
Having recently changed my dash I noticed why my timer doesn't work for the eber, its not connected to anything!
Having also done a google search that pulls up very little useful info (what a surprise!) I did find something from a few years ago regarding kps70 buying a switch and asking how to wire it up on Vzi...so Kieron if you read this and if you got yours working, how did you do it? Or is it still on the 'to do' list from 2006 :D
ALso if anyone else knows how to connect it up please let us know.
JSR-69
Re: Eberspacer timer wiring?
Post by JSR-69 » 10th March 2011 - 7:48pm
Have you looked at Jens Vagelpohl's Type4.org?
This page: http://manuals.type4.org/ba4/ch1/ba4_11f.html covers the wring diagrams for the Eber heater.
Judi
Judi R
1972 Karmann Ghia (sold)
1972 412 Variant Auto
shawn71
Post by shawn71 » 10th March 2011 - 8:29pm
Yes Judi, I found that one via google and as good as it is it doesn't show the connections on the rear of the clock or if they go straight to the switch or take another route.
kps70
Post by kps70 » 10th March 2011 - 10:22pm
Hi Shawn,
good question that one. I did get it working back then. I'll go out and have a look see what I did with the wires. They're kind of all dangling down in the 412. I might need a few days as work is mad.
K
Kieron
shawn71
Post by shawn71 » 11th March 2011 - 7:48am
Thanks Kieron, any assistance is gratefully appreciated
ARCANE
Post by ARCANE » 11th March 2011 - 9:03am
Is it the pre heat timing switch or the actual programable clock your after???
Mart
"A BLIND MAN WOULD BE GLAD TO SEE IT"
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
shawn71
Post by shawn71 » 11th March 2011 - 9:46am
I've got the clock in the dash with the 24 hour timer on it that currently isn't connected to the eber control switch in the dash. There are a couple of connections on the rear of this clock that aren't on other clocks I have that don't have the 24 hour timer so I'm assuming that these are to connect to the dash mounted eber switch but I don't know how at the moment.
Searches for wiring diagrams don't seem to include this part of the eber wiring circuit, or if they do I must be reading them wrong as I can't see the connections on any of the diagrams I've found.
ARCANE
Post by ARCANE » 11th March 2011 - 10:46am
Shawn try the wiring diagrams here just scroll down to the Type 4 section and select your model of car;
http://www.vintagebus.com
Hope this helps.
Cheers Mart :D
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
Post by Editor » 11th March 2011 - 11:57am
Hmm... needs a bit of translation!
shawn71
Post by shawn71 » 11th March 2011 - 12:17pm
Editor wrote:Hmm... needs a bit of translation!
and looking at that one the connections on the rear of the clock aren't shown either.
The clock is labelled 'Y' and the eber switch is 'E13'.
The actual diagram itself is great, just missing the bits I need as do all the other diagrams on the samba and the many other ones I've looked at.
ARCANE
Post by ARCANE » 11th March 2011 - 1:06pm
Here is a wiring diagram dont know if it will help as I dont have the optional extra clock timer so im kinda feeling in the dark a bit.
This can be found at Vintagebus again its under parts manuals scroll down to the bottom number 12 troubleshooting guide BA4 gas heater and its on page 025.
Cheers Mart
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
shawn71
Post by shawn71 » 11th March 2011 - 1:18pm
That's another one that I've viewed as well :)
Thanks for the help Mart but I think someone else has found the answer courtesy of the ratwell site
http://www.ratwell.com/technical/Tachograph.html
'There are 4 contacts on the back of the gas heater timer clock + the "hole" for the instrument light:
ground - unlabeled right tab (any brown ground wire will do)
+12V - rearmost tab at back of clock gets power from emergency switch (just as plain jane clock would)
B - left side, connects to terminal 30 on gas heater timer switch (power via fuse S9)
30 - left side, connects to terminal 4 on gas heater timer switch (bypasses accessory fuse S10)
Bosch terminal designations aside, this hookup is really quite simple: the clock timer acts as a bypass switch for the gas heater timer switch. When the clock timer is set the ignition key position (off) prevents the heater knob from activating the gas heater when you set the temperature. When the timer activates it powers the same terminal that the heater switch would if the ignition key was on.'
I'll pull the switch out later and double check it has the correct connections, fingers crossed :)
ARCANE
Post by ARCANE » 11th March 2011 - 1:43pm
Cool, good luck with it and post up your findings as it will be very useful to others.
Mart :D
WWW.DBS-VW.CO.UK
WWW.CTTP.CO.UK
Clockwork
Post by Clockwork » 11th March 2011 - 4:06pm
Looking at those wiring diagrams it all makes sense!
That's why I don't touch wiring :lol:
wenn es nicht luftgekühlt ist, dann ist es nicht cool
shawn71
Post by shawn71 » 11th March 2011 - 8:43pm
Didn't get chance to do this today as I've been swapping seat backs to regain my headrest which necessitated replacing broken springs. A job well worth doing as the seats are much more comfortable.
As for the timer I'll try to find time at the weekend or the end of next week when I've got time off, either way I'll report back how I get on :)
shawn71
Post by shawn71 » 12th March 2011 - 4:00pm
It works!!
The connections detailed on the ratwell link are correct and the eber now comes on with the timer.
kps70
Post by kps70 » 13th March 2011 - 9:39am
That's how mine works too. I wish I'd found that link before!!!
However, I was still left with the problem of my fuel gauge not working. Shawn - did you have to change your sender unit? Which fuel sender unit do you have in your 412?
Kieron
shawn71
Post by shawn71 » 13th March 2011 - 10:05am
My fuel guage is still dead as well.
I'm sure the fault is the sender unit/fuel tank end because you can earth the fuel sender wire at the tank end and the guage will read full.
The sender units are the cyindrical type that about a foot long. I've tried a couple of sender units and they have broken resistance wires inside of them that the float contacts with. I've read somewhere that this wire can be replaced with wire of the same resistance and then an extra earth wire attched which should fix the problem. A job I've put of doing for long enough I suppose but then the tripometer works and I know I can get 280-300 miles on a tank so filling up 200 miles will do...
Post by Editor » 14th March 2011 - 12:57am
See in workshop - we'll check the wire needed and get a supply -that's easier than guessing...
You may not need the extra earth wire -it depends what's making contact.
