exhaust
Just for 411 and 412 stuff.
bfr123
exhaust
Post by bfr123 » 21st June 2014 - 5:28pm
Hi Guys,
Where can I get a exhaust silencer from for my 412 LE, is the Type 25 the same?
Brian
1972 412 LE 2 Door Sedan (taxed tested used)
1979 VW Micro Bus (taxed tested used)
1975 VW Micro bus Auto (deluxe model with steel sliding sun roof) Just building it back up.
david412
Re: exhaust
Post by david412 » 21st June 2014 - 10:25pm
Hi, you just need a type 4 exhaust for a bay window T2. Heritage do a 1700 to 2000cc version, comes in two parts, the tail pipe is separate and comes out on the offside. Looks tidy though, i put one on my 412 LS.
1973 412 LS 4 door
1970 Bay - Devon Torvette camper
1986 Jetta C
bfr123
Re: exhaust
Post by bfr123 » 22nd June 2014 - 12:26am
cheers, thanks for the info
Brian
jonny rock
Re: exhaust
Post by jonny rock » 17th August 2014 - 4:15pm
Hi, in the past Iv use an end can off a Kawasaki motor bike. Might have to bend the grill thing up a bit. Also may need to enlarge the bolt holes a wee bit. Make you own gasket. A cheaper option. £10 off fleabay. Got one on my t25 at the mo.
Hope this helps even if a bit late on reply. :D
Jon
kgarchivinusa
Re: exhaust
Post by kgarchivinusa » 30th September 2014 - 6:16pm
Upper silencer is the correct style for the VW 412, the silencer below is T2 style.
