NRA28J
- Harding1600ta
NRA28J
Hi
I had to provide my insurers with proof of the value of NRA28J , Thought you might like to see the photo's I provided .///C:Documents%20and%20Settings/TedMy%2 ... img001.jpg
- Harding1600ta
- Harding1600ta
Any more information Ted?
If you go to the picture on AOL, right click and select Properties, it gives the Address (URL) of the image. That's what you need to put on this site, and then we will be able to see it here. If you put that URL in your message, highlight it and click Img in the panel on the message box, and then Submit, it will display.
I've just done this with their daisy picture on the log-in page, which has a URL
http://pictures.aol.com/ap/publish/imag ... _daisy.jpg .
- Harding1600ta
- Harding1600ta
nra28j
I will make another attempt using a different image .
- Harding1600ta
nra28j
Hi Dave ,
There is another series of numbers in AOL properties that does end with jpg - I will try that and see what happens !
ED: I've put a couple of the image URLs together and got this:-
http://shutter10.pictures.aol.com/data/ ... sNOOAO.jpg
Sandwich between the gives this:-
So it's possible, you just need to get the whole image from 'http' right through to '.jpg'. You need to carry on with the highlight for a third row! But first the pics need to be there again!
- Harding1600ta
nra28j
In sheer frustation I have now deleted my pictures from AOL Public Galleries !
- nitro_warrior
A another victim of AO Hell !!!
That last link you posted wasn't a full url, for it to work it would need the http://www. bit at the start.
You could always practise on the likes of the type 3&4 logo above. Right click, properties, triple click to get the full address then post it in the
- Harding1600ta
nra28j
Hells bells and buckets of poo - success at last . Thanks Dave , combining the two numbers solved the problem !
- Harding1600ta
nra28j
For some strange reason this image links OK , but the others do'nt !
- Harding1600ta
nra28j
I've changed over to Photobucket - hope that I get a link this time !
- Harding1600ta
nra28j
Help - what do I do to show a larger image ?
Nice looking car!
shame I had to use a magnifying glass to see it
Seriously though, I use photobucket when I post any pics and I always use the bottom of the 4 choices they give
Email & IM
Direct Link
HTML Code
IMG Code
Clicking on the IMG Code copies the link and enables you to then paste the link by right clicking the mouse in the text window on the forum you want to post the picture on.
I think that makes sense
Email & IM
Direct Link
HTML Code
IMG Code
Can you check the size you are uploading them? This is from the IMG Code, but it's not a lot larger - certainly not as big as the one you managed higher up the page.
There's an FAQ on size of the image at:-
http://photobucket.com/faq?catID=68&cat ... opicID=463 or maybe other questions might apply, too.
- Harding1600ta
nra28j
Many thanks Editor and Shawn 71 - we silver surfers sometimes have a problem with new technology ! Hope this makes the link .
- Harding1600ta
nra28j
Another try .
I'll knock a few of the duds out - don't stop trying things, something's bound to work soon! (Editor)
- nitro_warrior
