my new 68 squareback
hi all just joined
been waiting for this car to come up for 2 yrs
picked it up at the weekend
its been in a garage on blocks for 21yrs,was owned by the guy i bought it from new
found 4 small areas of rust ro repair so far but its porbably not going to need a repaint which is handy
body damaged on passenger side but ive also been given a door and rear wing to fit
just want to get the engine and brakes sorted 1st so i can move it about
- Danny Lord
- Paul Hayward
LITTLE BIT OF PROGRESS
took the fuel tank out and found about 5cm of black tar in the bottom of it,so its currently at feltham rads being cleaned and refurbed
the fuel line was perished and blocked,wasnt sure on the size so bougt some 8mm fuel line tonight
the front brake lines ive just made up in copper and fitted today the front rubber brake hoses look perfect and are still flexible so i will try those,not sure if the front calipers are any good yet
still not managed to get the rear hubs off as the adjusters are seized and the shoes are binding on the drums
i guess looking at the tank i might have to strip the carbs
From late 60's 7mm was used for tank fuel lines and at the rear there was a reducing sleeve for carbed models. 5/16" Goodyear rubber with reinforcement works well on tank to tunnel, and all fuel injection lines, though there are a couple of places where this is too large to fit through tinware holes with the grommet. Apart from the tunnel and tank line, nominal original for twin carb is 5mm, but this is pretty tight, and 5.5mm is easier and doesn't fail so easily where it's stretched over the pipe.
Modern versions of the original style cloth covered hose have a bad reputation. I like the proper cloth-covered stuff - a fuel leak wicks along the cloth and evaporates - I reckon it's safer than the drip you get from a leaking rubber hose that runs along the tinware looking for a source of ignition!
fuel lines
hi there
thanks fo the information
i will try the non covered line for the front section from the tank to the metal fuel line
but now after reading your post i will get some cloth covered pipe for the rear section,i never knew the cloth was used for that purpose,but i guess the front tank section,even if it did develop a leak,has no source of ignition so should be safe enough without a cloth covering
the place i normally go to for parts is a handy old style motor facotrs , but he hasnt any cloth covered fuel lines available
try here as been told good for a lot of hoses , not been there myself yet but will do when want something http://www.thinkauto.com/acatalog/Locate_Us.html
hoses and stuff
found a plce called unity motor factors that have teh braided rubber hose in stock in byfleet in case anyones after any
fitted the new fuel lines and refitted the freshly cleaned out tank
out an in line filter at the carb end and blew the solid petrol line out with some fuel and an airline
it started pretty much straight away and ticks over really nicely
1st running for 21yrs so well chuffed
got the new brake lines in made out of copper and new rear wheels cylinders and unseized the adjusters
new calipers on this week and then try to unstick the clutch !
ill post some more pics up if anyone wants to see the interior etc
well i know no1 on here lives near me but there a place in coventry called elliots i think they do it cus the hav a traders shop called oscotts n they do it and they sell the same things jus oscotts is for traders (n i get in on my dads account) and elliots is open to the public (but as my dads got an account with oscotts i get it as trade!) but i dont like that crappy cotton braided hose, its so poo! i had it on my bug n it had to go! so i got some of that really fat fuel hose with the string moulded in it and the rite size hole in n its much much better. its like the stuff they use on new carsEditor wrote:It seems hard to find the cloth covered stuff anywhere, and I don't have a lot of faith in it after the rubbish that has been sold. Bear in mind that quality will probably be close to £5 a metre. Maybe someone can vouch for a particular supplier of known good cotton-braided hose.
67 fastback
65 bug
KNOWLEDGE IS POWER!!
65 bug
We agree - the modern cotton-covered stuff is rubbish. I have to buy the internally reinforced Goodyear stuff - made in USA. It's a bit thicker than is ideal for some grommets.
VW did supply 5.5mm (carb engine) in a thinner rubber version - lovely stuff, but they wanted £10 a metre. then a year or so later said it was only available by the complete reel (I guess they didn't service many carb models by then, so wouldn't stock it).
I did find pre-packed cotton stuff in Halfords, but haven't tried it out - it's emergency only.
- Creationblue
Re: my new 68 squareback
Lovely
Well, that looks really nice & untouched original
Has it really taken 4 years to get her on the road ? - thanks for posting
Yeah well Its taken 4 yrs but I guess it's just been I've been in no rush and I've been doing it at work if I get some spare time.im sure I could have done it in a year if I had to.
I did end up getting it painted in the end though as the original paint was tired and I wanted it to look shiny!
I've fitted the last chrome strip today and it's just great to be driving it about.
I'm still not really wanting to sell it to be honest,but I've bought a bay and I've never had a t2 before .
Well the paint job looks really original. What type of paint has been used ? I'm thinking of getting mine redone, and I want it to look original, but haven't a clue if cellulose type paints are even available now, I understand most paints have had to go towards water based, but it's not an area I have looked at yet
Don't worry about the 4 years, being new round here I just picked up on the gap between the posting dates, some restores take 10 years or more, let's see how mine's doing in another 9
It was done in 2pk not the new water based ones as they need to be lacquered
I did try to get some of the 1k acrylic it was painted in when new but couldn't find a supplier
The local bodyshop supplier I use just mixed it up on site
If you wanted to paint it yourself you can still buy cellulose but will have to shop around,it's not as hard wearing a finish but easier to apply and not so toxic .some say it's more original to look at than 2 pack
That is incredibly beautiful!
Just needs a tickle with the lowering stick!
Nice car.
Nice car.
Die Schwarzen Schafe........
Dear
I am a cardiology Resident for masters
My passion is about vws since childhood but lack of opportunity. And. Made hurdle so
But I proudly own a genuine 67 beetle economy 1200cc 4 years ago
Now I am in search of a type 3 right hand drive
Not available in my country
Could you please help me find a mint car so that I can bring it in to my country
Best regards
Dr kashan
Best regards
Dr kashan
I think we're all looking for that mint Type 3!
Which country would that be, Dr Kashan?
