Page 1 of 2
type 4 sees daylight after 15 years!
Posted: 7th January 2009 - 2:24pm
by wil
Hi all,
My girlfriend & her sister have just inherited a 411 LE...it's been tucked away for 15 years
Here it is...
Their farther (who owend the car) was a former Type 3 4 member.
I'm looking forward to pulling it out & getting it going & cleaned up.
Cheers for looking
Posted: 7th January 2009 - 4:18pm
by shawn71
Firstly my condolences for your girl friend and her sisters loss.
Secondly..... Wow!!
Wish I could inherit something like that insyead I think when my parents go all I'll inherit is bills
There seems to be a few Type 4s coming out of hiding now. Good to see.
Posted: 9th January 2009 - 4:17pm
by wil
Cheers Shawn71
I'd love to get it on the road for Dubfreeze but I think that's pushing it!
Hopefully be ready for stanford hall...
Posted: 9th January 2009 - 5:43pm
by shawn71
We're hoping to get up to Stanford Hall again this year.
From what I have heard sounds like there might be a couple of others as well.
Look forward to meeting another Type 4 owner.
Posted: 9th January 2009 - 7:30pm
by Dubster
Yep, my target is to get mine on the road for Standford Hall, with a little bit of luck we should have a good turnout
Posted: 10th January 2009 - 6:58am
by Danny Lord
Cool, look forward to seeing it at some of the shows
Danny.
Posted: 12th January 2009 - 2:28pm
by wil
Can anyone tell me the correct battery I should buy?
Also - does anyone know the fuel line diameter? It’s the fuel injection model.
Posted: 12th January 2009 - 4:36pm
by shawn71
I replaced mine with a Bosch one S4005 540A(EN)60aH
As for the fuel line I replaced mine but can't remember what size it was, sorry.
Posted: 12th January 2009 - 5:58pm
by shawn71
I knew it was somewhere on here and now I've fed the kids I've found it
viewtopic.php?t=2690&highlight=fuel+pipe
follow the link
Posted: 12th January 2009 - 9:29pm
by wil
Excellent! Thanks for the info...
Here's a pic of the engine...
Still compiling a shopping list to get it running.
Posted: 12th January 2009 - 11:53pm
by Editor
It's hard to find the correct cotton braided 7mm fuel line in good quality, so I suggest you use good quality 5/16" which is a bit easier fit and doesn't split so easily on the spigots. There are a few places where the thicker wall will be a bit tight. you'll probably need new clips most places anyway. The engine cover plate is one of the tight places ISTR.
It looks well cared for - lucky you!
Posted: 13th January 2009 - 9:02am
by wil
Editor wrote:It's hard to find the correct cotton braided 7mm fuel line in good quality, so I suggest you use good quality 5/16" which is a bit easier fit and doesn't split so easily on the spigots. There are a few places where the thicker wall will be a bit tight. you'll probably need new clips most places anyway. The engine cover plate is one of the tight places ISTR.
Thanks for the info...I had trouble with fitting 7mm fuel lines to my bay camper. I installed twin carbs which requiered 7.5 mm fuel line but I couldn't find any so used 7mm which I thought was good quality. Around 200 miles later the pipe had started to break away internally (at the ends) & caused havoc with the carbs. Many hours of fun spent tracking that problem down!
Car seems to be in good condition & I'd love to tke it on but I think the girls want to sell it on asap as the garage is costing them money. I'm still trying to convince the girlfriend it won't take up all my spare time + the cost of an extra garage will be ok....
I'd like to at least get it on the road again!
Posted: 13th January 2009 - 4:08pm
by shawn71
I found that the shorter pipe in the middle from the crankcase breather has quite a strong vacuum through it and kept on collapsing the original breather pipe I replaced it with.
In the end I had to use a thicker wall 1/2 inch car heater hose.
Not the original red colours I'm afraid but servicable on a daily.
On looking at yours I notice a few extra bits that aren't fitted to mine, firstly the little pipe fitted to the top of the bent connector on the top of the crank case breather box?
You air filter looks different too?
What is the silver rectangular box in the lower left corner of the picture> Is it an electronic ignition of some sort as it looks like it is attached to the coil by the yellow wire?
I'm just being nosey
Good luck with gaining permission to keep it for a little while at least...you might even prefer it the bay
Posted: 13th January 2009 - 5:04pm
by wil
shawn71 wrote:I found that the shorter pipe in the middle from the crankcase breather has quite a strong vacuum through it and kept on collapsing the original breather pipe I replaced it with.
Hi Shawn - If I remember I'll take some more detailed pics of the bits you mention the next time I see it.
You're welcome to have a look if you're ever over this way - i'm usually around at the weekends
I can't ever imagine selling the bay...I've put soo much work & time into it over the past six years it's part of the family
Posted: 18th January 2009 - 9:15am
by wil
Hi - went over to the car yesterday to pull it out (my god these cars are heavy!!!) & had a look at the bits you mentioned.
The small pipe from the breather conection is capped closed...I imagine the "U"fitting isn't the right one.
Not sure if the airbox is different - i've only got my friends T4 motor in his van to compare with & thats running twin carbs so no filter.
The silver box must be EI - White wire to dizzy, yellow to coil & brown to earth.
Hope this helps
Posted: 18th January 2009 - 9:11pm
by wil
Posted: 19th January 2009 - 9:44am
by easy
Love that
Posted: 21st February 2010 - 10:46am
by wil
Hi guys - can't belive it's been over a year now since I last got the chance to work on this!
Just a quick update for you...
Out it comes...
Quick clean...
Off to a bigger garage so I can work towards getting it on the road...
More updates to follow
Posted: 21st February 2010 - 11:48am
by shawn71
Great to see it in the sunshine. And the colour of it is fantastic!
How long do you think it will take to get roadworthy?
Posted: 21st February 2010 - 1:28pm
by wil
shawn71 wrote:Great to see it in the sunshine. And the colour of it is fantastic!
Hi - I'm not sure how long but I need to get it on the road asap! Watch this space...
Posted: 21st February 2010 - 2:32pm
by shawn71
Any plans to make any shows with it this year?
And lets hope its easy to get back on the road, is it going to be a daily runner? Mine is and its great...most of the time
Posted: 21st February 2010 - 3:33pm
by wil
shawn71 wrote:Any plans to make any shows with it this year?
Yeah hopefully make it to some one day shows. It's not going to be a daily runner as i use the tube every day - so don't drive that much anymore but it will be out on the road ready to go
Would be good to line up with some other type 4's at a show
Posted: 21st February 2010 - 3:41pm
by shawn71
Cool...Hope to see you parked next to mine later in the year then
Posted: 23rd February 2010 - 2:31pm
by ARCANE
what colour is that absolutely love it great looking car well done nice to see you giving it some TLC
Posted: 23rd February 2010 - 9:48pm
by wil
I found the paint mix codes the other day...i'll have a look for it...
