1971 Fastback KBY 217K winter 2016 tidy up
muddy
Post by muddy » 30th October 2016 - 6:13pm
So I've recently purchased a lovely white fastback.
I drove it back home from oxford some 130 miles and it's gone straight in to my garage for a winter tidy up.
It looks like a relatively strong car, and has had plenty of work done on it. There are signs of welding patch work, and has had a full respray at some point.
Over winter 2016, I'm going to tackle the floor pan, suspension and engine. Fit new carpets and get the interior re-upholstered, ready to show in 2017. In winter 2017, I'll do a body re-spray.
So this weekend I started stripping her down, ready for a clean up and paint.
On 5 ton axle stands:
Fuel tank removed
Front slamworks narrowed beam, steering box and tie rod arms removed.
Next I'll be removing the interior to see what it's like under the carpet.
1973 VW Type 3 1600 TE Fastback. Under restoration
muddy
Re: 1971 Fastback KBY 217K winter 2016 tidy up
Post by muddy » 20th November 2016 - 9:41pm
A couple of weeks ago I stripped out the interior.
Bad news was then bestowed upon me when the removal of the carpet unveiled a peppered floor, specifically the drivers rear footwell.
muddy
Post by muddy » 20th November 2016 - 9:49pm
So this last couple of weeks I have been pondering what to do.
I have decided to do a body off restoration, and invest a bit more money than I had previously budgeted for.
So, over the next few months I shall be:
1. Repairing the floor pan. Using cut up repro beetle floor pans.
2. Re-painting the floor pan, subframes, beams and IRS.
3. Renewing all brake lines, fuel lines.
4. Replacing the front discs (Cross drilled) 5x130 pattern, bearings, calipers etc. (Machine 7 kit)
5. Replacing the rear drums for a CSP disc kit
6. Replacing the master cylinder
7. New accelerator and clutch cables.
8. Engine strip down and clean. Full engine EMPI gasket set. Paint all metal work. New fixings.
9. Repair rot in the rear quarters.
10. Replace heater channels (Or just inner sills) and outer sills.
11. Replace chrome trim.
12. Re-paint body shell.
13. Re-build.
14. Re-trim of interior.
15. New carpet
16. New wheels.
That's it for now it think.
muddy
Post by muddy » 20th November 2016 - 9:53pm
This weekend it's been busy.
I removed the engine, split off gearbox and put engine on a stand ready for clean, strip down.
All wings removed.
Body split off pan.
muddy
Post by muddy » 20th November 2016 - 9:55pm
Found lots of rot in both rear arches below the engine mounts. It's superficial, so a few metal plates here and there will tidy it all up nicely.
The front was pretty much spot on, has had lots of previous work so I don't think I need to touch it, other than a sand down and paint when the time comes.
jmarkha1
Post by jmarkha1 » 20th November 2016 - 11:11pm
Fast work muddy - nice one.
keep up that pace and you'll get thru the rebuild this winter.
keep the photos coming - cant beat a good resto thread...
Marko
Post by Marko » 21st November 2016 - 7:24pm
looks a nice solid shell, always a good start! and working at my pace too, I like to get jobs done and not hang about!
Mark.
viewtopic.php?f=4&t=6896
muddy
Post by muddy » 13th June 2017 - 9:43pm
Apologies for not updating. I spent most of winter doing bits and bobs but didn't really progress the restoration.
Anyhow, I've been busy the last couple of months.
So here are some pics of the repairs carried out on the floor pan. Some edges have been replaced and repaired. Passenger side rear floor replaced, i used a karma ghia floor section. I couldn't justify £500 a pan half from C&C. 90% of the pan was solid.
Some of the bad bits
Some of the metal work
I've wire wheeled the whole floor pan beam and rear subframe down to bear metal and treated with rust treatment
muddy
Post by muddy » 13th June 2017 - 9:52pm
So floor pan wire wheeled down to bare metal.
Rear sub frame removed and wire wheeled.
Front beam wire wheeled.
All treated to POR15 metal prep to treat the metal and any remaining rust. Great stuff, used it before on a rat rod resto mod. Also treated with Fertan rust treatment.
muddy
Post by muddy » 13th June 2017 - 9:59pm
2 weekends ago I started the first phase of painting.
Floor pan, rear subframe, front beam and fuel tank all painted with POR 15 semi gloss rust protection. This stuff is awesome if you've prepped properly. It sets like stone, doesn't let any moisture in, so the rust cannot grow.
Once I get another good weekend, I need to do the reverse side of the floor pan. Then the underneath will get a stone chip layer using Upol gravitex and then finally everything will get a gloss black top coat.
muddy
Post by muddy » 14th June 2017 - 7:35am
Last weekend I stripped down the engine.
Everything is now off it, tinware needs cleaning and de-rusting.
An elring gasket set has been used and as many seals that I could replace have been replaced. So hopefully it will be leak free when it's re-built.
Going to hopefully paint the tin ware, starter motor, dynamo, top of engine block and fan shroud this coming weekend.
Here some strip down pics:
muddy
Post by muddy » 15th June 2017 - 7:37pm
Another update. Been busy tonight.
This week I've been prepping the engine tin ware and accessories ready to be painted.
Tonight have treated everything to POR15 metal prep and painted with gloss black engine enamel. Had to battle a against the wind tonight though.
I'll finish everything off tomorrow night, will be painting the engine block (top of it) and the fan shroud.
hopefully get the engine built back up this weekend.
Bits ready to be painted:
Painted:
Post by Editor » 21st June 2017 - 1:23am
The foam on top of the oil cooler is important for making the air flow through the fins rather than over the top in the gap between the tinware and cooler. I'm not sure of the spec on that.
Post by broady_6 » 11th July 2017 - 8:58pm
your photos are all dead sir :(
muddy
Post by muddy » 17th July 2017 - 8:00am
broady, yes just seen this.
Seems Photobucket have changed their policy. Looks like I need to find another place to store my photos. Any ideas?
muddy
Post by muddy » 17th July 2017 - 8:01am
I've got loads of photos to add too. done loads of work.
Post by broady_6 » 19th July 2017 - 10:50pm
Imgur or flickr and reasonable places. Free lunch won't last forever, I expect they will end up charging one day. But they're free for now. Otherwise google drive had some free space too 😃
muddy
Post by muddy » 8th August 2017 - 9:42pm
I've finally sorted a Flickr account and will slowly add the new links for pictures.
muddy
Post by muddy » 9th August 2017 - 9:12pm
So now that I have all the pictures on flickr, heres a few updates.
Engine has been cleaned all parts painted (Didn't bother painting the block as I thought it would look odd.
muddy
Post by muddy » 9th August 2017 - 9:16pm
Floor pan treated with U-Pol gravitex stone chip.
Actually applied really well. I was impressed.
muddy
Post by muddy » 9th August 2017 - 9:24pm
Next was getting the body shell sorted.
First I decided to strip off the horrible black stuff on the front inner wings. Petrol did light work of this.
After degreasing the wings I applied POR15 paint stripper.
Both wings now down to bare metal. The metal is in great condition. I need to strip it back to address some previous metal work done by previous owners.
muddy
Post by muddy » 9th August 2017 - 9:32pm
Next the biggest job of them all, the metal work.
So first I tackled removing the inner and outer sills.
Then removed all the rotted out metal. This included all the over plating that previous owners had done. This just encourage more rust. So I cut it all out and made everything flush.
muddy
Post by muddy » 9th August 2017 - 9:35pm
more welding:
Post by broady_6 » 13th August 2017 - 7:36pm
Coming on a treat there sir! Good work relinking your photos, its giving me the motivation I need for a few months time to crack on with mine
muddy
Post by muddy » 21st August 2017 - 6:09pm
Thanks Broady, wish I had the motivation tbh. Seems a chore now. But I must complete this as I wasn't my garage back. Hopefully beginning of October it will be ready.
Who is online
Users browsing this forum: No registered users and 2 guests
